Strange behavior on Command
Old Nov 20, 2001 | 11:59 AM
sorlo's Avatar
E350, S320, Mini Cooper S
Unhappy Strange behavior on Command
My command doesn't behave normal recently. It whether says: "your location is on an unknown road" (which is strange because I have tried locations where I have been to before), or does not respond for at least 5 mintues.
Does anyone know why?
Old Nov 20, 2001 | 01:53 PM
bennett's Avatar
Try cleaning the cd. It may be sluggish.
Old Nov 20, 2001 | 02:22 PM
awiner's Avatar
2003 CL55 AMG
Are you able to go into your COMAND menu where it shows how many satellites you are receiving ? This may be a sign that you have lost total GPS reception. This happened to me and I had to have the whole COMAND unit replaced. I have also seen this happen when for some reason the GPS antenna goes bad. Maybe MBtech208 can provide some insight here.
Old Nov 20, 2001 | 09:39 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
I just fixed a 2001 CLK430 with a misbehaving navigation system. It wouldn't find local destinations, such as the local mall. It would only find far away destinations like San Francisco and Berkeley. The CD was scratched badly, it needed a new CD. Try cleaning it first.
Old Nov 21, 2001 | 12:38 AM
sorlo's Avatar
Command menu
Thanks for the replies. I have tried to clean my CD but the problem didn't go away. I was going to take GMAT yesterday at a location where I needed to use the command and it didn't work!!!
Hey Awiner, how do I go to the Command menu to see how many satallites I am recieving from?
Thanks in advance.
Old Nov 21, 2001 | 12:55 AM
sorlo's Avatar
Awiner, did MB charge you for replacing a new COMMAND?
Old Nov 21, 2001 | 01:05 AM
mbtech208's Avatar
Sorlo, even though you didn't ask me, I can tell you. Press "NAVI MENU", select "OPTION" and press enter. From the next screen, go to "GPS Information" and press enter. Then it will disply your current latitude, longitude, elevation, current location, and number of satellite signals being received.
Old Nov 21, 2001 | 01:33 AM
awiner's Avatar
2003 CL55 AMG
Re: Command menu
Thanks in advance.
Sorlo, no the COMAND was replaced under warranty. It's a good thing too as the COMAND head unit is a $4,000+ part.
Old Nov 21, 2001 | 06:38 PM
sorlo's Avatar
mbtech208, thanks for the help. I couldn't find "NAVI MENU" and then "OPTION". Is that only available for post 2000 CLK?
Old Nov 21, 2001 | 06:51 PM
awiner's Avatar
2003 CL55 AMG
Sorlo, look in your manual. It will tell you how to see how many satellites you are receiving as well as Longitude and Latitude... This is the screen that you need to get to.
My COMAND is v2.5 (Whereas yours is v2.0) so I don't know if I tell you how I get to that menu will help. I can try though if you can't find the procedure in your manual.
Old Nov 21, 2001 | 07:43 PM
karl k's Avatar
2002 CLK 55 AMG Coupe ;)
Today I was in an eight story parking garage and the command - when I pushed map - showed exactly my location as I was twisting/spiraling my way out of this billion ton re-enfoced concrete structure, in downtown Miami.
