BRIGHT WHITE lights... which ones are good?
I have my Stock bulbs in my CLK right now. I want to get new bulb that give off the effect of the BRIGHT-WHITE bulbs. Sometimes they even look blue. Can you guys recommend which bulbs are good? Is it pretty easy to replace all the bulbs? Is it recommended to replace ALL the bulbs? (Fogs, highbeams.. etc)
thx guys
-eso
If it is the latter, I wanted to get similar headlamp intensity (or as close as possible) on my non-HID lamped SL as on my HID equipped CLK without resorting to changing the entire headlamp bucket assembly. I ended up getting some PIAA Platinum series 65/45 Super Whites (perform like 110/85 halogens), and while not HIDs they are a vast improvement.
I haven't checked the CLK applications, but you may be able to use the even whiter PIAAs (Super Blue?) there. As far as the lamp monitors, I've had no problem with false outage reports etc.
Check ebay for the best prices.
Hope this helps,
Paul
I elected to go with their 80 watt set over the 55 w. They are brighter due to the extra wattage, but I have never been FLASHED by oncoming cars. (and, no, it does not set off the malfunction light)
Oh, yea---- they cost about $39 a set for the H7 80 watt.
I bought a set from HIPER, 2 years ago and to date have had no problems. They are bright white with a slight blue hue when seen from the side.
1-877-24HIPER and www.24hiper.com
Hope they still have them.
I didn't bother to change the high beams or fog lights for several reasons:
1. You hardly use the high beams (plus the bulbs are not cheap)
2. You preserve the look of factory HIDs (i.e. HIDs are not used in the high beams or fog lights)
3. I actually like the contrast of the white lights next to the almost champagne gold parking lights.
