Are these offsets workable??
Old Mar 8, 2013 | 08:19 PM
ThatsMyDawg's Avatar
SL 400
Hello all,
Been searching here reading old post to learn about wheels and offset. Found some
17x7.5
17x8.5 wheels I want to buy
with 25 & 37 offset. Not sure what spacers I need if any. I read about what the numbers mean but found nothing on how far one can push the limit while staying safe and keeping a smooth ride.
So with the wheels and offset above will they fit on my clk or how can I make them work.
Thanks to those who offer help.
Old Mar 9, 2013 | 12:07 AM
dlbehrns's Avatar
99CLK320,
just remember that the oem offset is 35mm for the w208 so the lower you go in the number the further the wheel moves out. So, the 25mm offset would probably not work on the front. I have 32 in front with an 8" wide rim and I get some rubbing turning into driveway or bump too fast. but 25mm might work in the back and you would not need spacers. Spacers would move the the wheel further out also. Think about it: oem 35mm minus 25mm on the new rims and you've moved out 10 mm. Why would you need spaces?
Old Mar 11, 2013 | 10:05 AM
SL 400
I appreciate the feedback. I'm just trying to get a grasp on the offset thing, a little rough understanding it at times.
I get having to move wheels OUT with a spacers but not sure if a wheel can be moved in if needed? Some have mentioned fender rolling as an option.
I checked with the seller and he cleared up that the offset is not a stagggard set up. I misread what he told me. He said he either has all 4 in 37 offset or all 4 in 25 offset. I guess in that scenario the four in 37 is the easiest route?
So if I understand correctly (and I may not) I would need a spacer in 2mm? To make it fit as my current wheels do if going with the four 37mm wheels? Am I correct?
I understand no more stagg with this set up. This is the first car i had staggard anyway. My other mercedes does not have a stagg set up.
Old Mar 11, 2013 | 01:25 PM
CurYousGee's Avatar
2000 CLK 430
37mm might work but not positive, but inwould suggest assing on it and sticking to a staggard setup
Old Mar 11, 2013 | 10:44 PM
dlbehrns's Avatar
99CLK320,
"So if I understand correctly (and I may not) I would need a spacer in 2mm? To make it fit as my current wheels do if going with the four 37mm wheels? Am I correct?"
You would need a 2 mm spacer to bring it back to 35mm which is the factory spec however, 37m would probably fit as is (depending on the width of the rim) on the front. You have all kinds of room to move on the back. But you may not get the look you want. And, staggered(and someone correct me if I am wrong) means the back rims are wider than the front, usually an inch if it came from the factory that way and would probably wear a different tire size.
Old Mar 11, 2013 | 10:54 PM
SL 400
My factory AMGs are 8.5 rear and 7.5 front. The possible new wheels are 8 all around.
I'm thinking since I loose a half inch on the back because of the wheel being 8 rather than 8.5 I should go one more size spacer to make up for the loss 1/2 ".
Hopefully a few more will chime in with opinion and this possible change.
Thanks to both of you.
Old Mar 12, 2013 | 09:02 AM
dlbehrns's Avatar
99CLK320,
what brand and style are you looking at?
Old Mar 12, 2013 | 08:57 PM
CurYousGee's Avatar
2000 CLK 430
If you go the spacer route , which i do not recommend, make sure there is enough room on the hub for the rim to mount on to otherwise all the weight will be on the bolts and there might be problems there
Old Mar 13, 2013 | 05:37 AM
SL 400
They are AMG 5 spoke knock offs. They look the same. Cant remember the brand.
Old Mar 13, 2013 | 10:45 PM
dlbehrns's Avatar
99CLK320,
Huh?
I think what he is implying is, if you are going to get spacers get hubcentric spacers.
Old Mar 14, 2013 | 06:50 AM
SL 400
Thanks for all tye help, I guess I'll just go ahead and get my wheels repaired.
