Loose Shift Knob
Old Mar 18, 2013 | 11:09 PM
Titus's Avatar
'16 C300
Loose Shift Knob
After a project cleaning out the shifter assembly today, I was reinstalling the shift knob onto the shift lever.
The knob is reinstalled; the lower ring rotated clockwise to lock the knob in place, but the knob still isn't good & tight onto the shift lever. I've messed with it & messed with it but no luck.
Old Mar 19, 2013 | 10:16 AM
Limited Edition 190E's Avatar
2005 CL65 AMG
Maybe it's not seated far enough down on the rod? You could always wrap a layer of electrical tape around the rod to tighten up the fitment.
Old Mar 19, 2013 | 06:54 PM
ThatsMyDawg's Avatar
SL 400
When you say " not good and tight" do you mean you can kinda wiggle it left and right?
If you confirmed it is down far enough on the shaft and you are saying what I mentioned above then you probably did not get the knob completed loose before you started pulling it off. It would still come off but after trying to reinstall it, it wont grab correctly anymore.
I mention this because I did the same thing and then the knob jiggled left to rignt when I grabbed from that point on and it got on my nerves. It would not come off but just wiggled a little. It was nice and snug before I removed it incorreectly. I had to replace the knob to correct it. Since I learned how to take the knob off correctly, the new one stays snug each time I put it on after removing it.
Best wishes.
Old Mar 20, 2013 | 12:42 AM
Titus's Avatar
'16 C300
Best wishes.
Yes indeed, it is exactly how you've described...
Where did you get your new knob from?
Old Mar 20, 2013 | 05:50 AM
SL 400
I had a few available to me at one time second hand. What color is your current knob?
Old Mar 20, 2013 | 10:24 AM
Titus's Avatar
'16 C300
It's light grey.
Old Mar 20, 2013 | 07:42 PM
SL 400
Give me a few days, I'll try to find you one cheap.
It's light grey.
