terry
Old May 2, 2013 | 06:16 AM
TerryWatts's Avatar
clk 320
terry
good morning, i need HELP 1st my convertible roof would not open i got help,
from two members thank-you for that ,when i went to close my roof the ,
motor kept on working so i took out number 13 fuse from the boot to stop it,
burning out put fuse back in and rear head rest have gone up and wont come,
down i have tried the switch up and down all i hear is a clicking noise open the,
roof and the head rest don't move do you think the motor is burt out regards,
terry ,new member , all-so i can not find where you can put a screwdriver ,
down the side of the head rest my car is a clk 320 sport 1999 convertible .
Old May 3, 2013 | 04:55 AM
TerryWatts's Avatar
clk 320
think i will have to book my car in to Mercedes at Northampton as no one can help me on ,
here so thanks any way terry.
Old May 3, 2013 | 08:58 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Terry,
Unfortunately, the lack of response was more than likely due to your choice of the subject title.
The forum 'search function' is your friend.
You will find pretty much everything you need pertaining to convertible roof repairs, that members have contributed through the years.
For example open the following link:
http://www.tophydraulicsinc.com/en/c...y-instructions
Then scroll down to the W208 topic and click on:
Rear Bow Lock Replacement, Case Cover Lock Replacement and Hydraulic Fluid Flush(3.5Mb).pdf
Old May 3, 2013 | 03:55 PM
Andy11UK's Avatar
1999 CLK Cabriolet 320
Sounds like the roof relay has gone, mine did the same (not the motor running) clicked but nothing happened, i got a new one from Merc for about £12 I think, the danager could be the motor may have burned out, however it was still running when you pulled the fuse may be OK,
The relay is next to the pump, but you need to remove the metal panel to access it not hard but a bit of the pain, I'd recomend some trim removal tools to pop the trim pins off
Old May 4, 2013 | 04:03 AM
TerryWatts's Avatar
clk 320
hi and thank-you for your reply ,yes the motor was running when i took the fuse out i left,
it a day went back to it and put the fuse back in and the motor was quiet ,started the car up,
and the rear head rest went up and now they wont come down all i hear is a clicking noise,
think i will have to book it in to merc garage as i am no good at car repair and see how much they will charge me to put in on there star -indie diagnostics regards terry and thank-you.
Old May 4, 2013 | 04:27 AM
Andy11UK's Avatar
No probs just be a bit careful as I had the roof codes read at an local garage with the correct kit (£45) and it said something like "low power to motor" and this could send them off in the wrong direction,
The fact the motor didn't turn off means the relay is def a gonner and should be replaced straight away before it burns the motor out, not that its working away
If you look in the boot at the back there's carpet, remove this and then the metal cover has about 20 nuts and its behind there - I would guess an hours labour,
http://www.benzworld.org/forums/w208...-problems.html
Old Jun 4, 2013 | 01:25 PM
TerryWatts's Avatar
clk 320
Angry the sun is out
hi rear head rest went up cant get them down book it in to mercedes northampton and they said the solenoid had gone and they wont £4000 to put it right and yes my rear head rest are still up so can not enjoy the sunshine as can not get roof down can anyone help me please thank-you .terry.
