Who's spring pad picture?
Old Sep 4, 2003 | 04:25 PM
rob_fed's Avatar
W204 C300 2010
About a month ago, I was searching this forum for spring pad pictures. I downloaded a few and I changed the names so I could identify them later. I found this one, I remember it was from a CLK, can anyone identify the photo?
If so, I was wondering about the spring compressors used in the picture. They look like the external type, with two seperate threaded rods. Were you able to get the springs out of the car with this type of spring compressor? Or were you only able to exchange the spring pads? Also, did you use the compressors on the rear springs?
Sorry for all the questions, I am ready to do my E-class and I doing my research.
Thanks in advance,
Rob Lee
Attached Thumbnails Who's spring pad picture?-front_compressed_wstockpad_clk.jpg
Old Sep 4, 2003 | 04:33 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
so you planning to do this yourself?
Old Sep 4, 2003 | 06:57 PM
rob_fed's Avatar
W204 C300 2010
Yes. From other posts about this subject, the +$500 factory style, internal spring compressor, seems to be the best way. Another forum user, scorchie, indicated that he could remove the front springs in about 10 minutes. When I was found this picture, I noticed, what looks like, external spring compressors. I have these already. If I don't hear back from the picture owner, I guess I can try. I only want to change the spring pads, but if you can get the coil out too, this would be a bonus!
Regards,
rob lee
Old Sep 4, 2003 | 07:01 PM
mmgrad's Avatar
Regards,
rob lee
yeah, because the springs are separate fromt he shocks, most places will use those portable spring compressors... the concept is simple enough, and if you already have the equipment, then why the hell not...
maybe once you complete it, you can help other members on the forum install suspension pieces... make a few bucks on the side... or you can do it outta the kindness of your heart... hehehe..
I might wanna change my pads to be a little thicker soon...
Old Sep 4, 2003 | 07:41 PM
Chappy's Avatar
AMG
Rob,
That appears to be a photo of Frank Way's CLK55 (wayfst) from this thread....
https://mbworld.org/forums/showthrea...threadid=39125
Hope this helps
Old Sep 4, 2003 | 07:43 PM
Chappy's Avatar
AMG
Rob,
Hope this helps
Old Sep 5, 2003 | 11:31 AM
rob_fed's Avatar
W204 C300 2010
Thanks Chappy! It does help!
