CLK430 soft top problems
Old Jul 23, 2013 | 10:58 AM
billybobbenz's Avatar
CLK430
I have a2001 CLK 430 cab. The roof has stopped working. Benz tells me the temp sensor on the hydraulic motor is sending an overheat message and will not engage the motor. They say the sensor can not be changed that it is part of the motor. The part is 208-800-10-48 at a cost of $7141. Any comments to help me
Old Jul 23, 2013 | 01:02 PM
Yidney's Avatar
2008 CLK550 Cab
Did you type that number right? $7,000 for a top pump? No way. You could buy a new transmission for that. A place called Top Hydralics is a forum sponosr. I suggest you e-mail them. Seem like very good people.
Old Jul 24, 2013 | 01:29 PM
CLK430
Yup, that is the number that the Benz dealership gave me $7141.00 Cdn.
Old Jul 28, 2013 | 01:32 PM
Top Hydraulics's Avatar
SPONSOR
03 SL Kleemann, 97 SL320 pano top, 95 Lorinser E320 Cabrio, Ferrari 360, Tesla X
billibobbenz,
thanks for your separate message. I didn't see your post before now - we are in peak season and I don't have much time for browsing forums... :-)
I would be surprised if only the temperature sensor in the pump was bad, but it is certainly included in our rebuild/upgrade service. http://www.tophydraulicsinc.com/en/w...ulic-pump.html The temperature sensor is inside the electric motor, and it usually goes bad only when the motor burns out (because everything in the motor starts melting, including solder, plastic, and sometimes even the copper windings). That means, we will probably have to replace all the guts of the electric motor inside your pump (outside of our regular rebuild/upgrade of the pump). The motor on the CLK pump is unique, and it cannot be purchased separately.
The most common reason for the electric motor on the pump failing is a stuck relay. We always install new, proper, high-current relays with the pumps, by the way. The following link includes directions for access to the pump and relay: http://www.tophydraulicsinc.com/W208...eplacement.pdf. Removing the pump from the car is easy, once you have followed the above guide to get access to the pump. Unplug the electrical connector, remove the socket head bolts from the retaining plate for the hydraulic lines, pluck out the lines, unbolt the pump from the car - done! Don't forget to drain the fluid before shipping the pump. Protect the white cone on the relief valve, although it's not terrible if that one gets crushed.
BTW, we ship inside the US double-boxed inside a USPS Priority Mail Large Flat Rate Box for $15. We prefer to ship in the same box internationally, because the international rates on USPS Flat Rate Boxes are hard to beat.
The following part numbers apply to W208 CLK hydraulic pumps:
2088001048 aka A 208 800 10 48 (early model years)
2088000230 aka A 208 800 02 30 (intermediate model years)
2088001748 aka A 208 800 17 48 (all models starting with VIN -070018)
Last I heard, Mercedes does not sell new CLK pumps in the US - what you get from the dealer is a core exchange for a rebuilt pump at some insane 4-digit figure. $7k is about the highest I have heard, and the highest numbers usually come from Canadian customers.
Klaus
