bleeding rear breaks
Beginning at the passenger side rear, bleed that caliper until the fluid comes through clear (old fluid will be darker). Then bleed the drivers' side rear. The passenger front is next, then the drivers' front. Personally, I rotate between ATE Blue, and ATE 200 every other year. They're both the same fluid and cost about $12 per liter. The Blue has blue dye, and the 200 is a natural gold color. The reason I rotate between those two colors is because when I flush the system, I can see that I'm done at one corner because the color changes.
