Cabriolet Position Sensor Logic Diagram
I have removed the rear seats, roll bar / headrest assembly in preparation to install a custom rear stereo system, if you have been following my posts this W208 was heavily mashed up by the previous owner - and of course the top does not work.. I need a diagram of the position sensor logic to bypass the circuit and "close the loop" to allow the panel mounted trunk switch to work, and the top closed position sensor to "see" the correct closed circuit. Last weekend I checked the position switch located above the left front seat (passengers seat here in Trinidad) and the unit is fully functional.. I presently get the annoying "Beep Beep" upon initial drive - and the cabriolet up / down switch continues flashing, while the rear headrest up / down switch middle light glows red constantly. Thanks so much in advance...
Bruce
Trinidad & Tobago
You will find all the information you're asking for here.
https://mbworld.org/forums/clk-class...-problems.html
