19x8.5 wheels.....what size spacer???
Old Sep 10, 2003 | 08:05 AM
CiLKY's Avatar
13 S550 4Matic
Hey guys I'm buying a set of 19x8.5 BBS challenge wheels for my 99 clk-430. The offset is 35 all around, so I was going to run a spacer in the rear to get a nice flush look, does anyone know what size I'd need or who sells them the cheapest? (oh yeah current tires on the rims are 235/35)
Jeremy
Old Sep 10, 2003 | 11:23 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Re: 19x8.5 wheels.....what size spacer???
Jeremy
Congrats... I saw those wheels on our classifieds section...
if you want a flush look, i think a 10-12mm spacer should be good. just make sure they are hubcentric spacers...
15 or 20mm is a little too extreme
Old Sep 10, 2003 | 03:15 PM
nickv's Avatar
Used to be a CLK430
I'm running a 12mm, but a 15mm would be ideal. Good luck, let's see the pics!!
Old Sep 10, 2003 | 03:30 PM
Mach430's Avatar
I would also say 12mm-15mm. Make sure you purchase a H&R spacer (so it is hubcentric), and buy at least a 10mm spacer in order to have a hubcentric lip built into it. There isn't much room on the stock hub, so with some wheels & a 5mm spacer, no hub is left over for the wheel to rest on.
Old Sep 10, 2003 | 05:01 PM
CiLKY's Avatar
13 S550 4Matic
ok sounds good everyone.......so who has 15mm H&R Hubcentric spacers? I had a link to a site but my computer has crashed since then and I've lost the link. The cheaper the better!
Jeremy
Old Sep 10, 2003 | 05:47 PM
twboy's Avatar
So can you have a 5mm sapcer with hub centric ring as one piece?
cause you mention about at least a 10mm spacer in order to have the hubcentric lip built into it.
thanks
