W208 CLK230 windows does not close tight
1999 W208 CLK230
Hi! Can anyone help me how to adjust window to close tight (at the A pillar) - see attached pic (I purposely slip a piece of paper through the opening)...Thank you!
1 Post
'00 Mercedes 430/55 clk cabriolet
Under the door base in the skin of the frame are 2 plugs. Remove them to gain access to the bolts for adjusting the window fore and aft, in and out.
I had a garage do mine, they didn't get it exactly 100%, but I'm happy enough, cheaper than the dealership doing it!
1999 W208 CLK230
Hi Paul! TQ for the tips - sorry for asking too much - which one would be the one to correct my problem - don't want to touch the other that is perfectly set....TQ again
Hey guys when you adjusted the stops did you find that you got bounce back and if so would you need to re-set the window stops by disconnecting the battery and programing?
