Running lights
Old Oct 28, 2013 | 03:28 PM
lawrdent's Avatar
clk 430 cabriolet
Running lights
It looks like I have a blown bulb in my running lights. Easy enough to open lid and remove bulb on top of the running light (spring enclosed), but how do you remove the running light? I just do not want to turn or pull and break something. Any guidance would be appreciated. I looked on this forum as well as other locations and can not find any answers.
Old Oct 29, 2013 | 01:28 PM
lawrdent's Avatar
clk 430 cabriolet
found it
After no replys I decided to gingerly play with it. With long nose plyers I slowly twisted counter clockwise and gently pulled back and it came out. I replaced this 6 watt bulb with a sylvania 4.5 watt bulb cause that is all they had in stock. Very little difference in quality. Will order the 6 watt bulb and when it comes in will consider replacing it. Very easy fix.
Just an aside. After all the looking I did in this forum, had no idea there was a little tiny bulb UNDER the high beam. I thought that was the bulb that was out. Even other mechanics said that it was probably your wiring harness. AHHHH...such a simple fix.
