H&R or Eibach Springs
Old Nov 28, 2013 | 01:48 PM
etownbala's Avatar
02' CLK 430
Looking at buying a new set of shocks and springs. Currently looking at Koni Yellow Adjustable shocks but am torn on spring choice. I'm looking for good control without sacrificing too much comfort.
Currently it's between the H&R Sport Springs & Eibach Pro-Kit. Even looked at the Vogtland Springs. I'm hearing Eibach would be the most comfortable due to it's progressive rate springs...can someone with these units confirm?
Would everyone with these mods be so nice and post a pic of their setups and ride height. Also please indicate what kind of OEM spring pads you used I would be much obliged.
Thanks in advance.
Old Nov 30, 2013 | 09:21 PM
etownbala's Avatar
02' CLK 430
Someone has to have these. Or some pictures. Pretty pleasev
Old Dec 1, 2013 | 12:21 AM
Williams707's Avatar
2000 CLK 320
I have the H&R Sports Cup Kit for the past 5 years or so. Love it!!! You can check all my specs that I have posted in my garage.
Old Dec 1, 2013 | 04:10 AM
CJackson13's Avatar
W208 CLK55
I have had the eibach and koni set up in the past and loved it. The springs dropped the car about .75" in the front and 1" in the rear. The handling increase was amazing although there is still a little body role, nosedive, and acceleration squat. The setup works nicely, it is smooth, comfortable, and great for everyday driving. Hopefully your roads are smooth as well though. I always had my konis adjusted to the stiffest level because racecar, but i'm sure if you adjusted them to moderate/soft the ride would be much smoother on rough roads.
Now I have KSport coilovers and they are heavenly because they have 36 way adjustable damping and ride height
Old Dec 2, 2013 | 03:38 PM
etownbala's Avatar
02' CLK 430
Thanks for the feedback. What size spring pads did you use?
Old Dec 4, 2013 | 12:35 AM
CJackson13's Avatar
W208 CLK55
Just used the oem pads. I would go with a lower one on the front if I were to do it again.
