CLK REFUSES GAS???
Old Jan 18, 2014 | 03:10 PM
Narwal's Avatar
2002 CLK430
CLK REFUSES GAS???
Hi,
My 2002 CLK 430 all of a sudden will not let me pump any gas into it!
Tried at 3 different gas stations and the problem is the same. When I start to pump it shuts off like it was full (it wasn't). Impossible to engage pump fully. If I try to just dribble it in very slowly some goes in but much of the gas comes back out and spills.
No idea why this would suddenly happen.
Any thoughts??
Old Jan 18, 2014 | 07:06 PM
aqeelr's Avatar
2000 Mercedes Benz Clk 320
this happens to me all the time, some gas station pumps are picky. A lot of the time i can't pull the trigger(?) all the way otherwise it'll shut off. If we have the same issue i wouldn't worry
Old Jan 19, 2014 | 02:56 AM
MarcusF's Avatar
2002 CLK430
Sounds like your charcoal canister is clogged. Two vent lines from tank feed in and one goes from it. A simple tee and a vacuum line can be used to fix / bypass it.
