speedometer / cluster problems.
Old May 2, 2014 | 12:13 AM
myworld's Avatar
'02 CLK 320 2000 clk320
I removed my cluster this afternoon to replace some bulbs, and put chrome rings in the cluster. I took it out fairly easy. unhooked it, and took the cover off. The rings went on the cover and the bulbs on the cluster were changed. I put it back together the opposite way. Plugged the cluster back into the car, now the lcd for the temp and center lcd are very dark now. What did I do wrong putting it back together?
Old May 2, 2014 | 01:21 AM
MarcusF's Avatar
2002 CLK430
The bulbs behind those two displays failed. You'll have to either replace the bulbs and or clean the contacts. What you're seeing is common.
Old May 2, 2014 | 02:16 AM
myworld's Avatar
Thank you MarcusF.
