HID Conversion Kits
Old Nov 21, 2001 | 03:01 PM
apacket's Avatar
'01 CLK320
Question HID Conversion Kits
I have normal halogens in my clk and I am thinking about installing one of those HID conversion kits. Has anyone ever tried this?
Click here to see the kit
Are the reflectors the same color on the factory HID fixtures as the factory halogen fixtures? Is the front glass/plastic the same?
Basically, will using the conversion kit be like having factory HIDs?
Old Nov 22, 2001 | 03:00 AM
Daez_Nutz's Avatar
1994 E500
No, the beam pattern is different with the halogen lights. If you simply swap your bulbs with HID retrofits, your light will not be distributed correctly. The only proper way to retrofit HID is to buy the entire OEM lamp assembly. Evosport sells them, as does Bekkers.
