Sick of it vibration
Old May 17, 2014 | 02:59 AM
triplefiresoul's Avatar
CLK430
OMG
So I got rid of my 19inches, as it was warped, and was told it caused my steering wheel to vibrate.
So I traded in my 19inches, and went back to 17inches OZ opera, with brand new tires. The result??? The steering wheel vibrated even more than before. I was like OMG!!! What is happening.
In addition, the rear looks pretty ugly. My car is lowered on Bilstein B8 with HR springs. Any suggestions to make it look better on 17 inches? Need to re align the toe, camber? Raise the rear suspension. The front looks good, just the rear.
More, can anyone suggest the vibrating steering wheel. Already 1, re tighten the steering bolt, 2, changed lower ball joint, 3, Re packed the front bearings. Any other suggestions??
Tonight I am going to replace the steering damper. It was replaced 2 years ago, it should not be broken so quickly!!
Please view my new pics:
https://www.dropbox.com/s/54rfaf0iwbffykt/DSC_0152.JPG
https://www.dropbox.com/s/cg44hcrrjd7k4ka/DSC_0153.JPG
Cheers
Old May 17, 2014 | 07:39 PM
CJackson13's Avatar
W208 CLK55
If you want the rear to be flush with the fender youre going to need a massive wheel spacer.
Old May 18, 2014 | 10:04 AM
CLK430
How often is the wheel hub warped? I was told this could be a possibility.
If brake rotors are warped, it should shake while breaking, but I do not have those signs at all.
I am going towards warped rims.
Old May 19, 2014 | 06:05 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
As suggested the back will look tons better with a spacer. Im using 20mm hub centric spacers and although close they dont rub.
Old May 19, 2014 | 01:27 PM
squid23's Avatar
E89 Z4
I just returned from wheel straightening.
They charge you $10 (plus tax etc) to check whether your wheels are bent. Well worth it. Fixing it is more expensive but at least you can know why your car is vibrating cheaply and then go from there.
