Where this tube should go?
Old Aug 7, 2014 | 01:38 AM
driver2x's Avatar
Mercedes CLK 200, 1998, auto
I've got a tube hanging loose under the bonnet, see the image attached.
Could anyone with the same engine (M111) please take a picture of where it should go.
PS: The headlight lever and climate control flaps are not functioning.
Old Aug 7, 2014 | 10:54 AM
jonUF02's Avatar
2015 GL550 4matic
It's a vacuum tube. I think it connects to a rubber hose coming off the rear top of the engine. I'm not sure what a headlight lever and a climate control flap is, but they could be vacuum operated from this hose.
Old Aug 7, 2014 | 08:06 PM
driver2x's Avatar
Thanks, but the problem is that I don't see any hose sticking out in that area. May be you can pinpoint the spot on the image here where it should go.
Old Aug 14, 2014 | 10:06 AM
SuperChargerE55's Avatar
E55 AMG V8 Kompressor 2004 E 55 AMG Type: 5,439 cc (5.439 L; 331.9 cu in) Supercharged V8 Powe
Check other end
Strange. Looks miss placed, sry got the 112m enginen but what u have in the other end of the tube? Is white or hard to see?
Old Aug 15, 2014 | 04:40 AM
driver2x's Avatar
Problem solved, the white tube should be inserted into a black hose.
Found the solution on w202 branch (can't find the link).
Old Aug 15, 2014 | 06:52 AM
Super
Aha I know what you are talking about now I remember seeing that on my own to when changed spark plugs. What ever is for me don't know lol. I think WIS has a vacuum hose diagram ill have a look tomorrow morning european time. If I find one Ill get back to you with it as I take you might want it P.
