Passenger side mirror Reverse mode
Hi guys,
I was reversing today and noticed my passenger side mirror that moves down when I reverse is not working. Anyone know what the problem may be? thanx in advance for your assistance, I really like this feature.
CLK
Make sure that the the module you use to move the side mirrors is set to the right mirror. The right mirror does not lower if the module set to the left side.
Hope that fixes your problem.
try what Bjorn said...
if it still doesn't work... check to see if the mirror moves at all using the controls, if it moves the way you direct it manually, then its just a software glitch in the system... that can be easily reprogrammed by the dealer.
If the mirror doesn't respond to the controls at all, it could be more than just software problems...
2000 CLK 320
I had the mirror quit on me before during reverse even though I could still manually adjust it. Brought it in to the dealer and they said they replaced something which was under warranty. Since I back up to park into my garage, I wait 15 seconds until the mirror goes in the proper adjustment after parking then pull the keys out. I thought that method would help prevent future glitches in the mirror.
