Missing Lug Nuts w208
Old Feb 15, 2015 | 02:37 PM
bonedali89's Avatar
2003 clk320 convertible
Angry Missing Lug Nuts w208
Flat tire, went to change and NO spare lug nuts in car/trunk. when i change tire and put on full size spare the lug nuts that were on were too long for the spare Had to have towed. what size lug nuts for the spare do i need to order.
clk320 w208.
Old Feb 16, 2015 | 02:35 PM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
clk320 w208.
If you had a flat tyre (Tire) in the front then you can use the same length of bolt (lug) the extra thread will just tighten into the hub (Albiet a little stiff usually due to slight corrosion) but will be fine.
IF the flat was on the rear you were right to get the car towed as the wrong length of bolt will interfere with the handbrake (Footbrake) mechanism causing damage.
Just buy 4 standard lug nuts off ebay or at garage and cut them to length for your spare, just ensure you have at least 4+ full turns to tighten and you will be fine.
Old Feb 17, 2015 | 08:12 AM
demon.bloom1's Avatar
2003 clk320 cabrio
i had the same issue and easily found a whole set of spare tire lug bolts in the trunk of an e class at the local you-pull-it junk yard... 5 bucks and im good to go
