Dead dash pixels
Old Apr 29, 2015 | 08:28 PM
bbnotman's Avatar
CLK320 A208
Dead dash pixels
Hi all, I am in need of a repair for my dash as some of the pixels are dead, I have read a few post on this and it seems most people have a disaster when trying to fix them, could someone try to lead me in the right direction for a repair.
thank you.
Old Apr 29, 2015 | 08:47 PM
cindyclk's Avatar
Have used them...I'm in Massachusetts, so I dropped it off. Fixed and never had a problem since.
http://www.bba-reman.com/catalogue/P...x?category=598
Old Apr 29, 2015 | 08:55 PM
bbnotman's Avatar
CLK320 A208
Thanks for you reply, I live in Melbourne Australia, and I was hoping for an easy DIY but I dont like my chances.
Cheers
Old Apr 29, 2015 | 09:04 PM
cindyclk's Avatar
If you have searched the forum, there is a very detailed fix that many have tried...some worked and others didn't.
Old Apr 29, 2015 | 09:10 PM
2PRECISE's Avatar
clk55 amg
im selling my if you cant fix yours
Old Apr 29, 2015 | 10:16 PM
bbnotman's Avatar
CLK320 A208
From what Im led to believe, I cant just put another dash in my car as the odometer reading wont match.
Old Apr 29, 2015 | 10:18 PM
bbnotman's Avatar
CLK320 A208
Thanks CindyCLK I will try to find it, I only found unsuccessful attempts for the repair.
Cheers.
Old Apr 29, 2015 | 10:39 PM
cindyclk's Avatar
https://mbworld.org/forums/attachmen...luster-diy.pdf
Old Apr 29, 2015 | 10:59 PM
bbnotman's Avatar
CLK320 A208
Thanks for the link CindyCLK but I have the earlier (1999) model dash.
cheers
Old Apr 30, 2015 | 05:03 PM
PelicanParts.com's Avatar
SPONSOR
Not sure how relevant this video may be, but check it out
. Might be able to search around YouTube for a DIY. If you do and you do one, make sure to post up your fix here with pictures!
-Luccia
Old Apr 30, 2015 | 05:13 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
There is a gent on ebay offering the service, It is in California.
Check with your local spedo shop in Australia if applicable. I tried the taping method in the video with poor results but was using a very old new ribbon.
Next attempt will be with a heating tool affixed to a soldering iron. It is a lousy setup.
I carfaxed my veichle @ a friends lot and found the head was replaced by the dealer for this problem. now evident again. If you buy used it may require flashing by the dealer. Cannot confirm this.
Cheers Gator
Old Apr 30, 2015 | 07:38 PM
MarcusF's Avatar
2002 CLK430
For a pre-2000, I'd recommend taking it apart and having a look. It can't be tougher than lining up the clock/gear selector ribbon on 2000+ models. Having been down that road, I highly recommend taking a photo with a good digital camera or marking the current ribbon's exact position.
Old May 1, 2015 | 08:53 AM
bbnotman's Avatar
CLK320 A208
Thanks everyone, I don't feel confident enough to attempt this myself, I think I will just need to bite the bullet and go to a repair shop.
Old May 1, 2015 | 04:06 PM
MagmaRed55's Avatar
Magma Red W208 55 AMG, W203 C230 Kompressor Sedan 6speed M/T, W220 S500
I'm not too far from them. I could make a day trip out of it. Do you remember how long it took and how much they charge?
Old May 1, 2015 | 06:53 PM
cindyclk's Avatar
It was $185...on south shore...
1 (866) 573 - 2740
BBA Remanufacturing Inc
300 Myles Standish Blvd
Taunton, MA 02780
Old May 1, 2015 | 07:35 PM
MagmaRed55's Avatar
1 (866) 573 - 2740
Taunton, MA 02780
Appreciate it!
Old May 1, 2015 | 07:45 PM
cindyclk's Avatar
Just remember how the left and right cluster cables are attached...it's a little tricky maneuvering cluster when you are reattaching.
Old May 1, 2015 | 07:50 PM
MagmaRed55's Avatar
I'm an advocate of taking pictures of stuff before taking it apart. Thanks for the tip. I may try the $30 ribbon cable first, then go from their.
Old May 3, 2015 | 12:47 PM
Gundo's Avatar
2001 CLK430, 2012 CLS550
I've fixed mine as well as 2 of my buddies using the t-iron soldering bar with Teflon insert. It's not too complicated but must have patience when doing this. Also don't forget to clean contacts thoroughly after you remove the old ribbons so new ones completely adhere and have solid contact. I use acetone for cleaning prior to soldering new ribbons on. Also make sure the ribbons attach identically to how the old ones were lined up both one the circuit board and the LCD's (which is much trickier than on the CB).
If anyone needs a set of cables I bought a bunch of them and have 3 new sets I don't need for 2000+ clks with the 3 rectangle displays like the one in pelican parts video. They are quality and have adhesive backing which creates a strong bond after heated (no need for tape). $25 shipped per set. 2 for $45 in case you mess up.
Old May 3, 2015 | 02:09 PM
MagmaRed55's Avatar
I haven't gotten around to taking mine apart yet (it just came out of storage yesterday). Forgive me if this is a stupid question, but is there a particular reason for replacing the ribbon if the connection on either side is the problem? This will be evident once I've taken it apart I'm sure but I was just wondering.
Old May 4, 2015 | 02:40 PM
etownbala's Avatar
02' CLK 430
http://www.akspeedo.com is your friend
Old Mar 11, 2016 | 01:17 AM
HarleyW72's Avatar
2000 CLK 320 coupe AMG Edition
http://www.pixelfix.net/eng/mercedes.html
