Wheels on my 1998....and Xenon light
Rick
PS- Thanks MMGrad for the xenon light, though the new one is brighter and whiter than the other, which, is more purple. Is this normal...or is this a sign that my other light is getting ready to fail?? Thanks, again.
Believe it or not, I really like the OEM 16" wheels on my 1998 CLK320, despite my friends and other CLK owners disagreement. The only thing I would like to change is the rear wheel spacing. I think the car would look a little better at certain angles if the rear wheels were "spaced out". If I were to do this, what should I know beforehand, and what should I expect handle-wise and otherwise. Thinking .5-1 inch.... is that right???
Rick
lights do get dimmer as they get older, and when they are ready to die, it gets more yellow also... I sent you a light thats off a newer Benz, i wonder if its a higher K rating also...
What i suggest is to install the brighter bulb into the passenger side headlight, thats the one you need more usually
