#1 Pads & Eibach springs/Koni shocks
Old Feb 4, 2004 | 01:36 PM
benzinoben's Avatar
99 CLK 320, 2000 GSXR 750
Is anyone running this setup on thier W208? It looks sick but I swear after the springs and pads, the car dropped to almost a full 2+ inches. It looks tight, but the ride is rough, even after I put Koni adjustables. If I go to #2 pads, what should I expect the difference be between #2's and #1 pads? I am running rubberbands for tires and am thinking of moving up to a bit thicker of a tire to help smoothen things out. Also, I am about to get the RS kit put on and I have this wierd feeling I am going to jack the front of the kit up everytime I go up a drive way or come out of a drive way. Not sure if I want to pull the "mini truck" move everytime I use a drive way.
Old Feb 4, 2004 | 02:47 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Try # 3 pad and adjust the shocks to the softest setting. It will get better, but don't expect it to ride like it was before you lowered the car. There is a price to pay for looks and performance.
Old Feb 4, 2004 | 04:44 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Re: #1 Pads & Eibach springs/Koni shocks
i'm running #1 pads with my brabus setup... my drop is 2" flat all across all 4 corners..
the ride is still comfortable... i don't find harsh at all... but then again, my springs & shocks are different from yours...
Old Feb 4, 2004 | 04:45 PM
mmgrad's Avatar
Btw, I think Josh has Eibach w/ Konis... but he's running stock pads... I think... better ask him for sure...
Old Feb 4, 2004 | 04:56 PM
BrabusClK04's Avatar
W209
Re: Re: #1 Pads & Eibach springs/Koni shocks
Danny, WOw, a 2 inch drop. See Thats what i want to do too. I Have H&R with about a 1.5 drop all around, however i want to drop the front 1/2 more. I was told my the dealer that the spring pads are already a One. Is this true...ANy advice...??? thanks
Old Feb 4, 2004 | 05:19 PM
benzinoben's Avatar
Thanks for the reply..I guess I am not to worried about the stiffness, but I am worried that I am going to be extra careful when I drive. That concerns me. I think I may move to #2 or #3. Is there a way to look at the stock pads that came out of the car to see what they were?
It is a price to pay to look good...absolutely!!
Old Feb 4, 2004 | 06:24 PM
mmgrad's Avatar
if you want to know what # pad you have, once removed, just count the DOTS on the pad... it will have between 1-5 dots.. thats the # pad you have...
on a stock CLK from the factory, it really shouldn't have #1 pads...
i don't think the CLK can come with #1 pads because in the system, there is no #1 pad meant for the CLK... you'd have to ask them for a #1 pad for a W210 E-class...
Old Feb 4, 2004 | 06:49 PM
theine's Avatar
Put your car on a lift, and you will be able to see the dots on the pads from underneath.
Old Feb 4, 2004 | 07:47 PM
W209
What is the standard for the CLK W209 or the stock spring pad for....Front?.....Rear?. Thanks for the information guys. I like the drop already on the car, but would love and extra 1/2 all around from my H&R.
Old Feb 4, 2004 | 07:51 PM
XcvX's Avatar
i dropped my 3 series at least 2" and I won't do it ever again....though I think the aero kit lowered it even more...it is such a pain in the *** for a daily driver. Once I get a better cash flow and I can afford more then one car, then comes the tuner :-D ....BUT i definately already miss the handling of the lower stanced car
Old Feb 5, 2004 | 01:28 AM
benzinoben's Avatar
I hear ya..daily driving is a beeaatch. Thats why Im gonna go up a number or two on the pad and put a slightly thicker tire.
Old Feb 5, 2004 | 01:42 AM
mmgrad's Avatar
i'm not sure... but I don't think the newer W209 CLKs use spring pads... only the older W208 models do...
you may wanna double check on that though...
Old Feb 11, 2004 | 11:53 PM
3 bAn 2 PoW 0's Avatar
CLk320
hey danny,
i was wondering does your full brabus suspension came with shocks? or was it just springs? thanks
-Greg
Old Feb 12, 2004 | 12:17 AM
mmgrad's Avatar
Originally posted by 3 bAn 2 PoW 0
hey danny,
-Greg
you can buy them individually or as a kit... i bought them as a kit...
the kit comes as a set of springs & matching shocks... i love it, very nice ride...
Old Feb 12, 2004 | 12:33 AM
CLk320
where and how much did u get the kit? thanks
-Greg
Old Feb 12, 2004 | 11:27 AM
mmgrad's Avatar
-Greg
you can get them from brabus for like $1200+ for the parts, or $1800+ installed...
i got them from my local tuner shop for about $1300 installed...
Old Feb 13, 2004 | 05:01 AM
funky102's Avatar
2000 CLK 320
Could it be that the expensive price Brabus charges isn't just for the name, but there also other benefits?
Danny, what kind of setup did you have before your Brabus suspension? How do you find your current setup compared to the previous? Sounds like you had a good deal on the install, can you hook up a fellow MBWorlder when its time for me to change my suspension
Anyone else have any comments on the Brabus suspension vs. other brands?
Old Feb 13, 2004 | 11:32 AM
mmgrad's Avatar
Brabus... the cost is mainly just for the name i guess... its pretty comfortable overall, even with #1 pads...
I've driven a CLk430 with a CupKit, and I think its about the same... granted that car had the factory pads of #4 front/#3 rear...
This is the place that did my suspension... www.d2technik.com
the guys there are pretty cool... just get to know them, talk to them about cars... and they'll hook you up with a good deal
