headrest removal help?!
99 clk430
i'm in the process right now of removing my rear deck lid to dynamat it. It ratteles way to much when i turn up the bass. How do i remove the rear headrests?
Let just say its a PITA, I going to try to explain it, but it might not come out the way I want it.
1-filp the rear head rest up.
2-start with the driver side rear.
3-remove the platic covers front around the headrest bars thinkys.
4-get a a small screw driver.
5-on the driver side rear headrest, on the left of the two headrest bar thinkys, there is a small white button that has to pressed in, from the rear wind in towards the front of the car.
The hardest thing is trying to stick you head back there behind the headrest and seeing the little white tab and pressing it.
6-then your be able to pull the headrest out.
This is best done with some one else looking at what your doing and directing you onto the little white tab.
Hope this helps.
Brian
Hope this helps.
Brian
1 Post
4 wheeled car.
Originally posted by slowsupraTT
thank you very much...i wish i could do it right now, but its 1am. I'll work on it when i first wake up.
So does the same process apply to the W210?
1 Post
4 wheeled car.
I'm gonna have my shop do the dynamat, but I'm sure they've never done it on a W210, so I'll give em instructions on how to do it so they dont break anything, or charge me ridiculous labor because they couldn't figure it out
99 clk430
awww no wonder why...they were black tabs on my car. Well i'm almost there. i got the headrests off. I figured the rear deck would pop out after that. Guess not...
im having same problem been at for 2 hours still cant remove rear headrests. i removed 2 black tabs and banged the heck out of it im about to give up and take to dealer just to remove them. i need them off since im recovering complete interior. HELPPPP!
