Fuel Trim Error
Old Feb 23, 2004 | 02:55 AM
clkal's Avatar
01' CLK55
Fuel Trim Error
my check engine light came on , and the code error came up as a fuel trim error in bank 3 and bank 4. Has anyone had this code come up before? Can anyone tell me what kind of problem this is, and how much i should expect to pay to fix it?
thanks,
AL
Old Feb 23, 2004 | 11:41 PM
clkal's Avatar
01' CLK55
Re: Fuel Trim Error
thanks,
AL
any help at all guys?????
Old Feb 24, 2004 | 12:40 AM
Richard Galing's Avatar
W210, W220, W163, W164, C6
The (2) last fuel trim errors on my E430 was due to a defective air mass meter, running too lean...the culprit being a BMC CDA. Could also be a slow responding oxygen sensor or a vaccum leak...I suggest running a full OBDII diagnostic scanner.
Old Feb 24, 2004 | 11:57 AM
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
Re: Fuel Trim Error
thanks,
AL
clkal-
First off the car has no bank 3 and 4, but a bank 1 and 2. Perhaps its cylinder 3 and 4? (which would be bank one, 5 to 8 are bank 2)
Fuel trim is the deviation (up or down) from the base map for fuel volume. +/- 25% is all that the ECU can do. If you have a fuel trim malfunction the ECU is trying to add or remove fuel volume to reach a lambda target and cannot reach the lambda target value.
Typically a failed MAF is the cause. The MAF can fail and NOT set a MIL- the phenomenon is called "drifting out of calibration". The mass of air metered is not actual, which skews the fuel load calculation. MAF's are a huge ducumented problem and should be a warranty item, if you are out of warranty they are approximately $275. Also look for "false air leaks" which are leaks or openings between the MAF and the throttle blade.
Another possibility, albeit not as likely as the previously mentioned, is a fuel system problem like a weak fuel pump or restricted filter. Its wise to replace the filter every 20K miles as it contains the pressure regulator for the fuel system.
Old Feb 24, 2004 | 01:36 PM
clkal's Avatar
01' CLK55
Re: Re: Fuel Trim Error
Originally posted by KLEEMANN
clkal-
thanks for the info Kleeman....i checked the code error that was printed on my smog check papers, and you are right... it IS bank 1 and 2. Last night as I was driving my car, when I stepped on the gas, the car went nowhere. The RPMs just stayed at 3.5 and the car did NOT move. Also, the car was idling extremely rough. I'm gonna have to make an appt at the local MB dealer........ damn!
AL
Old Feb 24, 2004 | 01:39 PM
clkal-
Its sounding more and more like a MAF problem. The MAF is the primary load calculation for fuel delivery. Oddly enough it is alaso part of the "function check" of the electronic "gas pedal"- develop a problem with the MAF and you can actually loose the accelerator pedal function! This is typically in conjuction with a ESP error in the multi-function display.
A MB dealer should have this sorted for you in no time.
Old Feb 24, 2004 | 02:22 PM
fstrd1's Avatar
kleeman-
Wow! I learned alot just reading your response and I do not even have that problem ......yet
Old Feb 24, 2004 | 02:27 PM
We are here to serve
Old Feb 24, 2004 | 02:32 PM
fstrd1's Avatar
Old Feb 24, 2004 | 05:03 PM
nickv's Avatar
Used to be a CLK430
My MAF crapped on my 99 430 with the same codes...tough diagnostic, but easy fix. Good luck!
Old Feb 24, 2004 | 06:48 PM
Great informative write-up Kleemann...just wished I had these essential details prior to taking my car at the stealership...nevertheless, it's comforting to know that few members dedicate their time to go beyond just simple explanation.
Old Feb 24, 2004 | 07:50 PM
clkal's Avatar
01' CLK55
yes. Thanks for all the excellent info, Kleeman. I just made an appt. to take my car in on Friday. Hopefully it's not gonna cost me an arm and a leg.
AL
Old Feb 24, 2004 | 10:47 PM
BryBenz's Avatar
Hey retard, why dont you start suing MBUSA, your car shouldnt have any failure until approaching 100k miles. Just call the customer service ! they will give you a brand new car. idiot.
Old Feb 25, 2004 | 02:04 AM
jawong's Avatar
w201
ho damn...in for some more drama...
Old Feb 25, 2004 | 02:32 AM
Josh K's Avatar
Tesla Model S
Hopefully MB customer service will be more helpful/polite to customers than some the other people clkal's done business with LOL
Seriously, that kit thread got way out of hand, let's not pull the same childish **** with this one...
Old Feb 25, 2004 | 03:06 AM
clkal's Avatar
01' CLK55
Don't worry, Josh.... that kit thread was a one time thing to let everybody know about a certain shop's *****ty customer service. But I guess BRYBENZ thinks that my new thread is related to it in some way.
I called Autobahn Motors and Beschoff Motorcars and BOTH service advisors told me that it is standard policy at all Northern California NOT to cover the cost of a rental or loaner car starting Jan. 1, 2004, unless the customer's car is in for warranty service. I found that to be hard to believe, so I ended up calling Smythe European (which i really didn't want to), however, my service advisor there, Greg Clark, is authorizing a C-class loaner car for the entire time my car is at their shop. Pretty cool. Car goes in friday morning.
Old Feb 25, 2004 | 02:11 PM
fstrd1's Avatar
AMEN!
Old Feb 25, 2004 | 02:12 PM
fstrd1's Avatar
[QUOTE]Originally posted by Josh K
[B]Hopefully MB customer service will be more helpful/polite to customers than some the other people clkal's done business with LOL
These forums should be used for help not hate!
Old Feb 25, 2004 | 02:45 PM
Josh K's Avatar
Tesla Model S
Old Feb 25, 2004 | 10:43 PM
What ever is the underlying debate, I do not know- write it off to not paying attention on my part. Please let us all know what the dealer finds so we can learn from your experience.
Old Feb 25, 2004 | 10:57 PM
E55AMG99's Avatar
1951 Caterpiller D6
Maybe this is Smythe's way to get their customer satifaction numbers up. After all, low numbers is what let Beschoff in their back yard.
I've found that Greg Clark is a reasonable guy that will bend over backwards to make me happy. If it is the MAF and you are not too far out of warranty, ask him to see if MBUSA will cover it anyway since it is such a common problem.
Old Feb 25, 2004 | 11:09 PM
clkal's Avatar
01' CLK55
cool. thanks for the info. i had 2 other advisors there previously that pissed me off so much, i switched over to Beschoff and Autobahn. Since Greg Clark was willing to work with me this time, I'm going back to Smythe. =)
Old Feb 25, 2004 | 11:47 PM
E55AMG99's Avatar
1951 Caterpiller D6
Any time you have a problem at the Smythe service department, call Marc Freschett. He was my advisor for several years before he got promoted to management. He is the most helpful and dedicated person I've ever met. I think he has been with Smythe for nearly 25 years and is well respected by others in the industry.
Old Feb 28, 2004 | 02:20 PM
clkal's Avatar
01' CLK55
They found out what my check engine light was on for. It is a faulty mass air flow sensor. $550 parts/labor. I also had them look at my a/c which was on the fritz. They told me i needed a flush/refill and that a electrical temp control sensor was bad. $700 parts/labor. WHEW! i was worried that I needed to pay for a tranny rebuild. The 2004 C class they gave me as a loaner car for the weekend is pretty cool. only 600 miles. =)
Old Feb 28, 2004 | 06:55 PM
clkal- Looks like I was on the money- glad you are back on the road again!
