CLK 320 Shock Recommendation
Old Mar 15, 2016 | 11:35 PM
nerocl's Avatar
1998 CLK 320/W208
I'm looking for a bit of advice for my '98 CLK. I'm coming up on 110k miles and it's time to replace the shocks - it's currently sitting on the originals. I've read good things about the Bilstein B4's and B6's but would appreciate input from the forum.
Also, any thoughts on replacing the springs when I do the shocks? I'm not looking to lower the car, just get the ride back to where it should be and am not sure if the shock will be enough to do the trick.
Old Mar 16, 2016 | 12:45 PM
Hitman0187's Avatar
CLK430
I have always been a fan of Koni, that being said if you want to just ride the way the car was intended KYB or even the original replacements would be fine. Depends how much you want to spend as it always is in the end
Old Mar 17, 2016 | 04:42 PM
nerocl's Avatar
1998 CLK 320/W208
Thanks, thoughts on replacing springs when I do the shocks? I've heard its unlikely the springs will be worn out but not sure
