Which way to go 18" or 19" rims?
Old Mar 2, 2004 | 11:52 AM
TonyD's Avatar
2000 CLK430
Smile Which way to go 18" or 19" rims?
I have a 2000 CLK430 and not planning on upgrading the suspension. Just want to change the wheels. Please advise also on the tire sizes (front and rear). Thanks in advance.
Old Mar 2, 2004 | 12:13 PM
clkal's Avatar
01' CLK55
Re: Which way to go 18" or 19" rims?
by increasing your wheel size, and not lowering your car, your car will look as if it is a 4X4. If you don't want to upgrade the suspension, at least consider changing out your spring pads to close the huge gap that you will get.
AL
Old Mar 2, 2004 | 12:38 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Re: Re: Which way to go 18" or 19" rims?
AL
listen to Al, if you ain't gonna lower it or anything... don't change the wheels...
18s might be ok, but don't do 19s if u not gonna mod the suspension... it will look all outta whack...
Old Mar 2, 2004 | 01:56 PM
GaryL's Avatar
CLK 430
I'm considering the same option for my bone stock 01 430, but am hesitating for exactly the same reasons stated above. I was looking real hard at the 18" ASA ST4s from TireRack, but am worried about the appearance if I leave the suspension alone. (car is leased) I'm also woried about the unknown effect such a move will have on ride-quality and performance.
In my case, I need to make a decision soon, cause the tires are cupped, and at least one rim is slightly bent. Luke @ TireRack tells me I'll be OK with the proposed setup, but now I'm thinking that maybe sticking with 17s might be my best bet. Too bad the OEM wheels are so expensive. It's a tough call...
Old Mar 2, 2004 | 04:34 PM
fstrd1's Avatar
Thumbs up Re: Re: Which way to go 18" or 19" rims?
AL
Good advice Al!
