koni yellow question
Old Mar 5, 2004 | 10:10 PM
W2O8TC's Avatar
W208
I am finally getting my H&R springs/koni adjustables install tomorrow. What setting on the koni shocks will make my clk430 comfortable? I was thinking of putting it on the most soft setting which I believe its 5?? but I am afraid I will rub when I go up speed bumps, turning left/right on to bumped/hilled roads. Which setting do you guys recommend? I am running 18" E55 rims with 225/40/18 front, and 255/35/18. Thanks
Old Mar 5, 2004 | 10:15 PM
E55AMG99's Avatar
1951 Caterpiller D6
Re: koni yellow question
I don't think you'll have a problem. The tires are not that wide. 235/265 combo would be risky. I had that tire combo and EU AMG springs with #1 pads. Only a couple of rubs on the front inner fender when backing. Biggest problem was the wife bottoming out the front end on EVERYTHING! I repaired it 3 times before going back to stock.
Old Mar 5, 2004 | 10:27 PM
W2O8TC's Avatar
W208
so i wouldn't have problems with #5 setting?
Old Mar 5, 2004 | 11:34 PM
E55AMG99's Avatar
1951 Caterpiller D6
I never used the Koni's but unless you are flying over the speedbumps and driveways, the soft setting won't cause more bottoming than a firm one.
Old Mar 6, 2004 | 09:30 AM
turboriceco0ker's Avatar
Let me know how your koni/H&R feel..I'm installing that in the next 2 weeks.
Thank
Old Mar 6, 2004 | 07:57 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Koni Sport Adjustables for W208 don't adjust by numbers. They go from soft to medium to hard, that's it. Go with the softest setting, which is much harder than your original shocks, and take it from there.
