Change the oil in a W208?
2001 CLK-430 Black
If I plan to change my own oil in a CLK-430 2001 do I need a topsider oil changer to suck the oil out through the dipstick hole?
Also, what is the best weight Mobil One to use on the east coast?
Thanks in advance!!!
RK
RK
Re: Change the oil in a W208?
RK
RK
2001 CLK-430 Black
1 Post
w211 & w124
http://www.liquidvac.com/
http://www.boatus-store.com/webapp/w...169&storeNum=6
http://www.liquidvac.com/MercedesExample.htm
enjoy!
enjoy!
02clk55///2010GLK350
All the info that you need is at http://www.mercedesshop.com/diy_oil_change2.htm
I got mt topsider at JC Whitney online. Works fine and is well built. You do have to re-pressurize half way through suction.
1 Post
w211 & w124
2001 CLK-430 Black
I want to build an AC powered one since I would only be using it in the garage. This way, you dont have to mess with pumping and losing pressure! I am going to grab one of those Airplane fuel pumps and see if it can handle the viscosity of oil.
1 Post
w211 & w124
Alright, just got the topsider in from JC Whitney and my oil and air filters in from mercedesshop.com. I think I'm going to change the oil this weekend.
Can someone please confirm what type of oil to use on a 320?
Thanks.
Thanks.
1 Post
w211 & w124
Originally posted by seealkay
what's the topsider? The Guy changed my oil when i just got the car he did it from under the car. he took off a piece of plastic? under the engine or something. and let out all the oil.
1 Post
w211 & w124
I use Mobil 1 Synthetic 10/30
Also, nobody said anything about needing a special oil filter socket to remove the filter housing. I spent half an hour yesterday trying to twist that thing off by hand. Didn't even realize that the instructions I had said to use the socket and a wrench to remove it. I guess I'll have to order one. Anybody know where I can get one of these at?
TIA.
00' CLK 430
I use 0w40 and the topsider, i got one like this:
http://www.thetoolwarehouse.net/shop/MIT-7201.html
1 Post
w211 & w124
Originally posted by tery
where is the oil filter located ? do i need to go under the car ?
In this picture it's where the wrench is.
1 Post
w211 & w124
1 Post
w211 & w124
Get one at any local auto store. Make sure that you buy one that is the right diameter.
