2001 CLK320 Cab restoration
Old 11-17-2016 | 12:25 PM
BryanW203's Avatar
I bought the CLK at an auction for $500 with only seeing pictures. I knew it didn't run but had no idea why. When it showed up I popped the hood to find out the motor was locked up and had been removed, the AC compressor and the catalytic converters were missing, everything else was in the trunk. The car had been sitting for a while but had brand new Michelin tires all the way around and a new battery (but was completely drained). The car is a grey market car that was bought new by a woman in the military, she was the only owner until she locked the motor up and donated it to a local school. When they imported it they removed the leveling HID and front parking sensors . I looked into replacing them but it was out of the budget since I could only find the parts in Europe.
For the resto I replaced the motor with a used one with similar mileage. This is a list of what I replaced. The rear main seal, valve cover gaskets and breather seals, some vacuum lines, exhaust gaskets (when switching manifolds), intake gaskets, AC compressor and drier, trans pan gasket & 13 pin connector, new catalytic converters, new front/rear pads and rotors, cluster ribbon cables, 5 hydraulic cylinders for the top (have not replaced the rear headrest/roll bar cylinder), oil & filter, trans fluid and filter, coolant, new floor mats. I steam cleaned the interior, had dents removed and polished the car.
The car runs and drives very nicely. There are a few small things left to do. I need to replace the drivers front door window seal, the fuel sending unit went out on a long drive, the keyless entry does not work with rf but does with the ir. Trunk key cylinder need lubed and freed up. Cosmetically the drivers seat seams are ripped and the rear bumper could use a repair and paint but those will have to wait. I am currently trying to sell the car because baby #2 came into this world after this project started and a vert is not a very useful car with 2 little kids.
I am probably missing a few things but here are some pics.
Motor when car arrived
When car arrived
Motor out.
Very dirty interior.
Taking interior apart to clean all switches, seats, carpets and vents.
Repaired cylinders
Pump exposed to refill oil resivoir.
Cluster out.
In the middle of the rebuild.
Clean console.
Clean car.
Purdy.
It all works.
flapjack (11-26-2017)
Old 11-17-2016 | 09:28 PM
PKSlice's Avatar
2002 CLK55 AMG
W O W
You have my total respect. Question, I need to get my inner rear side panels off in order to fix a broken rear window stop. How do you get the panels off (armrest panels for back seats).
Thanks!
Old 11-18-2016 | 09:46 AM
BryanW203's Avatar
Originally Posted by PKSlice
W O W
You have my total respect. Question, I need to get my inner rear side panels off in order to fix a broken rear window stop. How do you get the panels off (armrest panels for back seats.
Thanks!
They are pretty easy to remove. They lower seat cushion lifts up from the front edge, pull up and remove. Then there are I believe 4 10mm or 13mm nuts that hold down the back rest of the back seat and 2 screws behind the armrest cover. Then lift up the rear back rest. On the top edge of the side panel there is a oval piece of plastic that the windscreen sits in, you have to push down the little cover and use a pic tool to release the tabs on the inside then there will be a screw there. Remove the l&r door scuff plates the fabric door seal, and the rubber gasket at the top. Then all that holds the panels on are 4 panel clips.
I had to fix the broken stop too. Its a stupid design with a plastic edge that breaks, I made my own bracket to fix the issue. Heads up, unless you are super lucky you will probably drop the bracket a few dozen times, it does fall in to lower quarter and can be a ***** to get back out, I had a few choice words for that bracket by the end of the day. It helps to remove the upper window seals and belt moldings. I checked but did not take any pics of that part of the resto, i should have but was just wanting to get this thing done.
PKSlice (11-27-2016)
Old 11-18-2016 | 09:48 PM
PKSlice's Avatar
2002 CLK55 AMG
Thanks very much. I am still impressed by the resto. When I saw the first few pics I thought uh-oh, but you pulled it off nicely.
Anyway I went to my local MB dealer and asked about the window stops, but they could not find it in the parts diagrams. Maybe it's called something else other than "window stop"?
Old 11-19-2016 | 05:27 AM
Raindance's Avatar
CLK320 cab
Well done ☺
BryanW203 (12-12-2016)
Old 11-20-2016 | 09:02 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Great restoration and you put a lot of effort into the car, good luck on the sale.
Old 11-20-2016 | 09:35 AM
PKSlice's Avatar
2002 CLK55 AMG
I'm wondering why you had to tear the whole interior apart?
Old 11-21-2016 | 09:29 AM
BryanW203's Avatar
Because I am a bit OCD when it comes to cleaning cars.
The dirt, dog hair, coffee stains and anything else you can imagine was every where. That stuff was in the switches keeping them from moving, console doors wouldn't open/close, just nasty between panels. Much easier to take it all apart and clean every piece. It also made sure I didn't miss anything and didn't have to worry about weird odors.
Old 11-21-2016 | 03:15 PM
PKSlice's Avatar
2002 CLK55 AMG
Hey can I bring my car over? This gives a whole new meaning to the word "detailing" lol
Old 11-27-2016 | 10:33 AM
PKSlice's Avatar
2002 CLK55 AMG
Hey I got the rear seat out, although the 2 screws behind the centre armrest was a mystery until I yanked away the inner cover. How did you ever figure that out?
Anyway I am stuck with the interior side panel and it's secured at the top edge somewhere... where is that oval with the hidden screw? Is it the 10mm nut hiding inside where the seat belt retracts? Very hard to get at it and I was nervous about undoing it in case it was the wrong one and stuff would let go flying... or is it the little flip cover hole that the rooftop clicks into when closing? I tried prying everywhere but don't see the retaining tabs and was nervous about breaking the part. I will send a pic next. Thanks for any help...!
Old 11-27-2016 | 09:03 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Yes , very nice! What type of equipment/cleaning material did you use in order to get seats so clean? Did you have deep spots to clean up? Thanks.
Old 11-28-2016 | 08:21 AM
mbdave87's Avatar
'99 CLK 320
Wow, simply incredible! Glad to see that people are starting to rebuild these...they're certainly a future classic!
I have a question: Could you provide more detail on rebuilding the convertible top hydraulic cylinders? Did you do it yourself? If so, where did you source the seals? I have a couple that are leaking...
Old 11-28-2016 | 09:26 AM
BryanW203's Avatar
I was a car audio installer for ~5 years and work as a service adviser at a MB dealer for 8 years, and currently work at a body shop so I have a few tricks up my sleeve.
The piece circled has the hidden screw. Push down the oval and you will see tabs on the left and right side. You will have to pull the tabs inward to get the cover off to expose the screw.
There is a 10mm nut under the trunk carpet by the red arrow.
PKSlice (11-29-2016)
Old 11-28-2016 | 09:31 AM
BryanW203's Avatar
Thank you!
I had Top Hydraulics rebuild the 4 cylinders that move the top and I had Steve at MB hydraulics (he lives about 15 min from me) repair the cylinder on the top cover. Both were easy and great to deal with. Now the removal and install of the 4 cylinders for the top... not easy to deal with.
Old 11-28-2016 | 09:48 AM
BryanW203's Avatar
I used a steam cleaner and a leather/interior cleaner by Malco.
This stuff is amazing. I use it on everything even the engine compartment.
http://www.smithtoolsupply.com/Shop_...0piBoCvXrw_wcB
2MERKS (12-05-2016)
Old 11-29-2016 | 09:24 AM
PKSlice's Avatar
2002 CLK55 AMG
Thanks for the tip on the oval trim removal. I tried hard and gave up because I was unsure, but now I will go back and get that side panel off. Do you know what MB calls the window stop? The could not find it in their parts diagrams and there did not seem to be a listing for "window stop".
BTW, do you know anything about setting the side windows so they drop about 1/2" when opening the doors? Mine only drop about 1/32" - almost nothing at all. The do go up&down upon exiting, but they don't move much. Resyncing did not help. All other window operations work proper.
Old 12-02-2016 | 09:48 AM
BryanW203's Avatar
That is one of the small issues I need to fix.
I have heard it may be the control unit. I have access to a salvage car so I might go steal all the door electronic parts and see if I can get mine to work.
Ill let you know what I come up with if it gets fixed.
Old 12-02-2016 | 09:57 AM
PKSlice's Avatar
2002 CLK55 AMG
Rear windows go too high on 2 door
Great, thanks. There does not seem to be any information about rethinking or adjusting for this feature so you could be right.
Old 12-02-2016 | 10:00 AM
PKSlice's Avatar
2002 CLK55 AMG
Pixel fix
BTW how did you attach the pixel ribbons? I bought a cheap set from China but I don't think it's pressure sensitive sticky. Some people use heat? Others just use Scotch tape?
Old 12-02-2016 | 02:06 PM
BryanW203's Avatar
I just used scotch tape.
Old 12-02-2016 | 02:12 PM
PKSlice's Avatar
2002 CLK55 AMG
Pixel fix ribbon
Great. I tried the sponge trick, improved, but not perect so will try taping new Chinese ribbons this weekend.
Old 12-04-2016 | 05:14 PM
PKSlice's Avatar
2002 CLK55 AMG
Pixels
Managed to get the left pixels working by burnishing down the ribbon contact points and sliding in a piece of credit card to press it down. The right side got partly fixed (gear selection perfect, clock about 50% good) with cheap Chinese ribbons but they are only carbon wires not silver. Will order silver ribbon and try again. I might have messed up the pixel display though, when I scraped the old ribbon glue off the panel, I used acetone, might have washed off contact points...?
Old 12-04-2016 | 06:39 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Wow. Amazing job man.
Old 12-11-2016 | 12:55 PM
PKSlice's Avatar
2002 CLK55 AMG
Okay I ordered these from MB up here in Canada. Also I got the interior side panel off, thank you. Those retainer clips for the over hide-a-nut are tricky to unclip. Now... I am looking everywhere but cannot see where the rear window stop is located. Can you help?
Thanks,
Paul
Attached Thumbnails 2001 CLK320 Cab restoration-side-panel.jpg   2001 CLK320 Cab restoration-window-regualtor-stop-clip.jpg
Old 12-12-2016 | 09:45 AM
sb53's Avatar
2000 CLK430 Cabriolet
Wow. Great job!
Quick Reply: 2001 CLK320 Cab restoration
