Clicking sound from the righ rear ??? help
recenlty when my car go over uneven bumps or normal city street driving where there are lot of small bumps. It make this werid clicking noise fromt he righ rear, but the car still handle like before, what could it be ? the sway bar ?
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Re: Clicking sound from the righ rear ??? help
Could you coment on the Schrick cam, that's my next mod. Did you re-map your ECU after installation? How much gains did you got.
i re-map my ECU frist then add the Cam. Cam gives me good gain, under 3500rpm you dont' really feel anything but once you get the rpm up it start to feel like a different car. i haven't put my car on the dyno yet still waitting supersprint header and highflow cat then i will send my ECU back to Renntech again. Hope i get some good power out of those mod. Cam i think should give me 20hp at the gearbox.
So you gave Renntech the cam specs for the ECU before installation. I am asking because I am going to send my ECU this weekend to Powerchip and get the camshaft afterwards. Powerchip will remap the ECU to the standard specs now.
not at the time i done my ECU i was't thinking about getting the cam. so the ECU is jsut purly their Stage II modifying with airbox give me 245hp at crank. But i from what i was told the MB ECU a speical kind of ECU, it will learn your driving style and stuff you add to the engine. But i think if you tell Powerchip the spec of the cam it will be even better. that is what i m planning to go after getting header and cat, then let Renntech re-map everything try if can get more hp out of all those mod. I didn't tell Renntech the spec of my cam but after i finish installing the cam i still feel the gain.
I've noticed you haven't gotten the evosport UD pulleys, they are good for 13 HP at the wheels, like 15 at the crank for $449 you can't beat them!
With the chip and evosport performance ignition stageI, I will have like 335 HP. Then I will go for the cam, to be at the CLK55 territory 355 HP.
i think i will get the pully last. i m tryin to get my car around 290hp to 300hp i still need a lot of work done. but i will try to keep my car NA. and i want to put Recaro SPG on to take off some weight, hope this help the performance.
