19" x 8.5" lorinsers LM6 on 2002 clk430
Old Mar 25, 2004 | 12:00 AM
phrankie2001's Avatar
hey this is my first post, whats up guys?!? question is... can 235/45/zr19's fit cleanly on the w208. i think i messed up. i wanted to buy pilot sport a/s's and they dont come in the 235/35 size that is recommended. am i fu@k3d?!? i would appreciate any help.
Old Mar 25, 2004 | 02:23 AM
Brian_I.'s Avatar
w211 & w124
Depending on if you want your car lowered you may be able to cut it although it will be very close. You are talking about a 23.5mm difference in the sidewall between the recommended and the one you got, which can cause major rubbing issues.
Old Mar 25, 2004 | 04:20 AM
clkal's Avatar
01' CLK55
is your car lowered at all?
Old Mar 25, 2004 | 07:34 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
You don't want the A/S anyway....
avoid it at all costs. The tire has an inherent right pull problem that shows itself on many cars, especially Benz. You're going to find your self limited in tires in 19" sizes anyway, but avoid the A/S like the plague. There are several discussions around this board about it, check the archives.
Old Mar 25, 2004 | 07:51 AM
hinhin7's Avatar
MB
If you dont lower it too much, then I think you would be fine. But then, your speedo will be much off though.
Old Mar 25, 2004 | 09:29 AM
thanks guys... i'll get rid of the wheels and get a set of staggered 18"s. Anyone know the ideal fitment for 18"s?
Old Mar 25, 2004 | 03:48 PM
auto2freak's Avatar
18" lm6????????????
I don't think lm6 has 18" Do you mean to change to other styles? 18x8.5F w/ 225/40-18 & 18x9.5R w/ 255/35-18 is the most common staggered rim & tire set up
Old Mar 27, 2004 | 11:18 PM
ELENI's Avatar
2006 E350
I've got 235/40/18 and 265/35/18 with no problems.
