COMAND hidden menu - pls try and send me info
Old Nov 26, 2001 | 04:22 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Hi
Im trying to collate info on software versions of COMAND in Europe and USA
So, if anyone would like to help, can U do this
Enter the hidden diagnostic mode on COMAND
- Select AUX input mode [press SYS button, select AUX from menu]
- Hold down Mute , 1, 3 all together
- Menu appears with "Processors" "Tuner" "Diagnostics" and possibly "Configuration"
Select Versions
Select Processors
collect FIS and S/W info
Press RET [goes back to Versions menu]
Select FIS
collect FIS, S/w and H/W info
[for those in the US, can you go back to the Versions menu, scroll down and see if you have a TV setting ??]
Heres what I have so far
MY2001 European COMAND from E Class
From Processors menu
FIS: Apr 4 2000
S/W Rel_V13.06
From FIS menu
H/W 11.0
S/w 14.0
Production Date 04.08.00
MB nr 210 820 54 89
MY2000 European COMAND in CLK55
Processors:
FIS Oct 8 1999
S/W 8.17
FIS Menu:
H/W 45.99
S/W 40.99
Production Date 09.05.00
MB nr 208 820 37 89
Old Nov 27, 2001 | 11:32 PM
jsr's Avatar
jsr
Wow...That menu is pretty cool. Too bad you can only view the settings and not change anything...
From my MY2001 US CLK55
From Processors menu:
FIS: Aug 9 2000 10:25
S/W: REL_V06.11
From FIS Menu:
H/W: 42.00
S/W: 32.00
Also, there is no TV Tuner area on the versions screen. The only reference I see to the TV Tuner is when you go into the Configuration from the main screen you see that TV Tuner is unchecked.
Old Nov 28, 2001 | 08:31 AM
Richard's Avatar
jsr - have you got the MB number for that unit
- something like 208820xxxx or 210820xxxx
Thanks !
Old Nov 29, 2001 | 01:16 AM
jsr's Avatar
jsr
Yeah, it is 208 820 35 89.
Oh yeah, and the production date says 06.02.01.
Old Dec 1, 2001 | 02:58 AM
odbenz's Avatar
2000 CLK430
MY2000 USA COMAND from CLK430
FIS: July 20, 19999
S/W Rel_V05.50
From FIS menu
H/W 45.99
S/w 40.99
Production Date 02.18.00
MB nr 2088203889
NO TV Menu Option
