2000 CLK430 Convertible
Things to consider in your decision making.
1) The chances of breaking your new plastic trim when attempting to install a new headliner are quite high. If you inspect the broken trim you currently have, you'll see the obvious difficulty that a novice would have in trying to properly attach new plastic trim to the rear window frame (Many professional uphostery shops flat out refuse to even attempt to install a new headliner on Mercedes CLK's because of past customer disatisfation, or their frustration with breaking the new plastic trim on their install attempt and then having to eat the cost when customers don't understand the difficulty involved with installation.
2) It'll take less than 1/4 the time to install an already complete top assembly with frame vs attempting a new headliner install. The headliner itself is fairly easy to install, but as pointed out above, successfully attaching the new plastic trim without damage is trial and error, and with a $500-$800 part, that's a foolhearty attempt imho.
3) Before you embark on a headliner purchase, call around to upholstery shops in your area and get their input. Take you car to them and let them have a look and get them to guarantee that they think they can successfully install. I suspect you'll find most backing away once they take a look. As and FYI, my local dealer wasn't even willing to attempt it, even though I suggested I might be willing to pay their outrageous premium.
Good luck!
*** I ran into a guy last year who had custom made his own trim out of fiberglass. He covered the fiberglass trim in carbon fiber wrap and used urethane adhesive (the type that's used to secure windshields) , and permanently bonded his custom trim piece to both the headliner and window frame. He definitely had talent and it looked better than factory, but obviously it's a permanent solution since there is no way it'll ever be debonded. Said it cost him less than $50 in parts for fabrication.
See post #19 at https://mbworld.org/forums/clk-class...placeable.html
