driver door will not open from outside
Old Jul 6, 2017 | 12:07 AM
drose789's Avatar
2000 CLK 320 conv
I have a 2000 clk 320 and the driver door will not open with the outside door handle
Old Dec 5, 2017 | 02:10 PM
flapjack's Avatar
W208
The handle might just have slipped off the mechanism somehow.
There's a pretty clear video of the handle here:
Old Oct 21, 2020 | 07:09 AM
hfount's Avatar
1999 430clk
my '99 (W208) driver door will not open with the outside door either (interior handle works fine). I have to use the metal key from remote to lower window and open the door from the inside door latch.
Took the outside door handle off the "mechanism" handle was correctly behind the Mechanism (around 2:40 in video above).
I sprayed grease into (outside) door handle as suggested here, it opened the door. However, it stopped again the next day, this happened a few days in a row.
The "mechanism" seems to be the problem. Does anyone know if that's the assembly or something else?
Old Nov 2, 2020 | 09:48 AM
hfount's Avatar
1999 430clk
Hi,
Took the outside door handle off the "mechanism" handle was correctly behind the Mechanism (around 2:40 in the video below).
Thanks in advance, Harry
