Which foglight bulb should I use ??
Old Apr 21, 2004 | 06:46 PM
lou430's Avatar
Im going with Piaa Extreme white but they come in three different wattage 35, 55, and 85 which lights like 135 watts same as HID. My question is going with the 85 watts bulb cause any electrical overload or any other problems like premature burning out.
I will change the driving lights after but wanted to get better lighting since the fogs are dim like my alternator has gone bad
Old Apr 27, 2004 | 10:11 AM
ldangeli's Avatar
EFF YOU JACKIE
You're talking the H-7's right? I believe that 85 is the most you can go. Ask your PIAA retailer, if they're good, they'll tell you.
Driving lights you can't change with PIAA's. It is a unique bulb that PIAA won't make because it burns out too quick.. If i remember correctly they did make it, and then stopped. You can change the Highs to superwhites, which is what I did, makes a difference as well. Its the same bulb (h-7) that goes in the fogs.
