99 clk 320 W208 code reader? OBDII or 38 PIN
Old Sep 25, 2017 | 04:43 PM
marcellomax's Avatar
1999 mercedes clk 320
I did some looking and there is an OBDII under the dash but that is for emission only? there is a 38 pin round plug in the engine compartment.
which location do i use to pull the codes out and which tool do i use?
i can find a lot of Icarsoft but those are for 2000 and up. so i am guessing i need a code reader for the 38 pin right? which model do i buy?
thanks for the help
M
Old Dec 1, 2017 | 01:45 AM
TiaZHANG's Avatar
BENZ
I bought Launch CReader 8011 specially to read ABS codes on my Mercedes Benz vehicle. I like that it comes with the storage case, USB cable and micro SD card to transfer data. It was amazing when I use it at the first time. Cleared the ABS code and gave me lots of data about my vehicle with the large and clear display. Moreover, it supports oil and epb reset,I was impressed with the product function.It may help you.
Amazon Amazon
Old Dec 3, 2017 | 07:52 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
I picked up a bluetooth OBD2 dongle from amazon around -12 clears codes in seconds..To get into serious diagnostics a C3/C4 reader must be used on http://www.uobdii.com/ the 38 pin connector by the ECU.
Cheers, Gator
Old Dec 4, 2017 | 07:53 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
You just need an OBD2 bluetooth with 38pin cable adaptor, then downloard Torque app on your phone, simple. !
OBD2 - https://www.ebay.co.uk/itm/ELM327-OB...mCZu2fi-dvbiEw
Cable Adaptor for 38 round pin - https://www.ebay.co.uk/itm/16-Pin-to...cAAOSw2GlXLFeO
£6.50 or $8.20 for both .
