just wanted to post picture of 2din radio in clk 200 kompressor w208
Old Dec 27, 2017 | 07:56 PM
Reggiexp's Avatar
Clk 200 kompressor w208
Cool just wanted to post picture of 2din radio in clk 200 kompressor w208
there are not much fotos about it. and since i installed mine and it looks sick some quick pictures. of a kenwood/jvc ddx4016bt 2din touchscreen radio installed. (also got a sub in the back 300W rms, 800w max and replaced the stock woofer with 2 16.5cm 65w rms focal coax speakers runing on my amp in the trunk) from speaker i disconected the 13cm ones. and replace the 16.5cm ones with focal (same serie as the back 165 iss) 2 way speakers with a adapter for the speaker in the door and the tweeters fit in perfect running from the radio to lazy to get a amp in the front) but i dont have steering wheels control for radio that is just dumb expensive..
clk w208 200 kompresor 2din radio
clk w208 2din radio double din
clk w208 2din radio installed
Old Dec 30, 2017 | 09:33 AM
jim9's Avatar
clk55
I noticed that your ashtray door is open. Will it latch when closed? Mine won't, and a M-B mechanic said "it's broken; just replace the whole assembly."
Old Dec 30, 2017 | 09:40 AM
Reggiexp's Avatar
hi, yes it closes but i use it to store usb stick money tiny thing. it does close but i never leave it closed lol its just a lil push tray i mean that you could probaly fix it your self but i have seen those latch on some cars not closing u press it down but it doesnt click.
Old Dec 30, 2017 | 11:18 AM
jim9's Avatar
clk55
Thanks for the reply. I don't how to fix it. You don't know how to fix it. An independent Mercedes mechanic doesn't know how to fix it. Perhaps someone who knows will eventually instruct us.
Old Dec 30, 2017 | 11:22 AM
Reggiexp's Avatar
did you try getting a new one? like the part?
Old Dec 30, 2017 | 11:27 AM
jim9's Avatar
clk55
The MB dealer is so high on other parts that I didn't ask. I'll check a clk 430 at a local junkyard when I get a chance, but the wood will likely not match..
Old Dec 30, 2017 | 11:32 AM
Reggiexp's Avatar
hope it will work. i mean clk are not that often in junkyards
Old Dec 30, 2017 | 11:50 AM
Yidney's Avatar
2008 CLK550 Cab
Can't say about a W208, but on a W209 CLK the wood detaches from the ashtray door lid. I'm betting the W208 does too. But if you have not removed it and taken it apart, you should. The mechanism is not that complicated. It just be something blocking it. You have nothing to lose.
Old Dec 31, 2017 | 03:09 PM
jim9's Avatar
clk55
ash tray door
Do you have any hints on how to get it out without breaking it? I've already broken pierces off of the overhead control panel and the back seat cup holder, So I'm wary of making it worse.
Old Jan 2, 2018 | 09:34 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Once you have the tray out it just slides up.
Old Jan 2, 2018 | 10:30 AM
jim9's Avatar
clk55
Do you have any hints on how to get the tray assembly and lighter socket out without breaking them?
