Check Engine Light!!!
I take it home and run my tester and find a PO170, PO173 and PO301. Two are fuel trim problems and the other has to do with a misfire in the engine.
So how does it all end, you say? I drive around the block and it runs fine.
So I restart the car two more times (making it a total of 5) and the light turns off and everything is fine.So the moral of my story (to myself at least) is that I should never let my gas run down so low.
I was driving from Santa Monica to San Diego, my gas empty light came on when I approached Ocean Side. So I reset my mileage meter to see how far it will take me with the reservoir. I figured I could re-fuel somewhere in Clairmont Mesa Blvd another 25 miles away. I was approx. 3 miles away from Clairmont Mesa Blvd and then my engine started to hesitated. POW!!! all systems shut down!! I was out of gas and only 2 1/2 miles away from the gas station.
To make a long story short..............I did had the same problem with the engine light came on. Drove the car for a day or two the car was back to normal.
oh yeah....................for those of you who don't know.....once the empty gas light comes the 430 can only cover 18 miles!!!
I went right past a gas station when the fuel light came on, then there was no gas station for some 60km.
Out of fuel, in the middle of the night, on a highway in Denmark. I was lucky to have my friend right behind me in his E-class...
/Martin
