need help clueless
Old May 13, 2004 | 07:09 AM
NJCLK430's Avatar
clk 430 desgno
need help clueless
I just got a 2001 clk 430 nad it has the voice and timeport system
I was wondering if i got the complete v60 system from a 2003 clk would it fully integrate into my system and if so how much would it cost to install and any recommended people to do the installation. thx for the help. By the way the 430 is the best car i have ever had I love it so far !!!!!
Old May 25, 2004 | 09:36 AM
ldangeli's Avatar
EFF YOU JACKIE
You'll have to go to the dealer for the phone and install. There is a special chip in the phone that allows interaction with the MB system.. I believe it is about 1400, but you have the basics, so it may be a lot cheaper.
Old May 25, 2004 | 11:22 AM
NJCLK430's Avatar
clk 430 desgno
THx for the info, but i have the complete kit and phone , just need to know how to swap out the timeport system with the new v60 system, anyone have instructions or have done this
thx in advance
Old May 25, 2004 | 11:29 AM
ldangeli's Avatar
EFF YOU JACKIE
Should all be fibre optics. You should be able to just unplug the one, and plug in the other...
Old May 25, 2004 | 11:43 AM
NJCLK430's Avatar
clk 430 desgno
Once again thx for all your help, have one last ? , where are all the parts like pse and voice control box located ? in the dash ? trunk??
Old May 25, 2004 | 12:11 PM
ldangeli's Avatar
EFF YOU JACKIE
The brain is in the trunk, and I believe that there is a junction box under the steering column..
Old May 25, 2004 | 11:43 PM
jddumas's Avatar
2006 E55 & 2009 Audi S5
Doesn't Steve do that mod? Maybe he'll give, or sell, you instructions on how to do it. I don't have his contact info but most on here do. My computer crashed so I lost it.
Old May 26, 2004 | 03:18 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
If it is from a 2003 W209... the antenna connectors are different. The brain would work, the handset would work, the compensator and connectors would need some work.
If it is from a 2003 W208... it would still be different, because the W208 coupe has three phone antennas, and the 2003 W208 (must be a cabriolet) has only two antennas... so the cab uses an antenna switch, and the coupe does not. So then again, the connectors would be different.
You can do it all, it just won't be plug and play like you want.
-s-
Old May 26, 2004 | 03:20 AM
scorchie's Avatar
For the phone, the PSE (or "brain") goes behind the left trunk panel; the compensator also goes behind the left trunk panel; the handset goes in the center console; the fibre optic wiring is under the panel on the floor of the trunk between the rear wheel wells, or it might be under the right C pillar.
Nothing that I know of under the steering column for the phone. Actually, nothing I know of at all under the steering column, except maybe an OBD connector off to the side mounted to the trim plate.
-s-
Old May 26, 2004 | 06:48 AM
NJCLK430's Avatar
clk 430 desgno
thx for the help but I have come to find out the v60 kit I bought is from a c320 coupe 2003 , will this cause any problems will i need further parts ?? thx again for hte help
Old May 26, 2004 | 03:29 PM
scorchie's Avatar
First of all, you never told us if you have a coupe or a cabriolet. So all of this posting doesn't really matter.
The mounting bracket definitely will not fit.
-s-
Old May 26, 2004 | 09:58 PM
NJCLK430's Avatar
clk 430 desgno
i have a clk430 coupe and it came from a c classs sedan
