**help** Need Comand Installation Instructions
Old May 27, 2004 | 01:53 PM
MBPhD's Avatar
I purchased the Comand from Steve for my 01 CLK 430 but there is no installation instructions in the package. Steve, or any one else, please help with installation instructions ASAP. My e-mail address is magiccorner@yahoo.com.
BTW: Do I need mounting brackets? Steve did not send me any.
Thank you.
Old May 27, 2004 | 11:56 PM
MBPhD's Avatar
Steve?
Anyone?
Old May 28, 2004 | 12:35 AM
Josh K's Avatar
Tesla Model S
Are you talking about the brackets mounted on the side of the COMAND? They should be attatched.
You don't need mounting brackets that attatch to the car itself, you just need to cut out the center piece in your existing bracket that separates the two DIN spaces.
Steve or Dean should get in touch with you soon re: the install instructions.
Old May 28, 2004 | 03:20 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Yeah, like Josh said... the brackets should be attached to the side of the COMAND already.
I will send an e-mail now...
-s-
Old May 29, 2004 | 04:26 AM
MBConvert's Avatar
Steve usually includes some install tips with the shipment, but the following directions will probably get you what you need:
http://www.ibex.co.uk/mbstuff/Retrofitting%20Comand.htm
http://mbclub.co.uk/forums/showthrea...&threadid=2883
The hardest part is cutting out the middle din slot and tapping into the speed sensor wire. I provided some directions on this a few weeks ago:
https://mbworld.org/forums/showthrea...158#post714158
Good luck!
Old May 30, 2004 | 03:00 AM
MBPhD's Avatar
Comand is up and running
Thanks for all the help, especially Paul (http://home.earthlink.net/~phdwebsite/COMAND%202.0.htm). Thanks Paul for your time and effort in helping me out.
