hydraulic roof oil re filling clk200 2002
Old Nov 17, 2018 | 11:00 PM
bit lost's Avatar
2002 clk200 convertible
once ive fixed the leaking part. How do i re fill the hydraulic fluid and where??
Old Nov 18, 2018 | 10:27 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Everything related to the A208 CLK hydraulics, can be rebuilt better than new by Top Hydraulics, who has earned numerous international rave reviews from forum members, dealerships etc..
Go to
https://www.tophydraulicsinc.com/en/content/53-mercedes-benz-a208-info , where you will a 12 chapter video series, that explains:
-The reasons why a hydraulic system component will fail
-The why and how a component needs to be completely rebuilt
-Detailed instructionals for accessing and replacing any of the system components
As example, in chapter 2; which covers the removal of the hydraulic pump, you'll also find additional details showing how you can easily check the reservoir fluid level and if required, how to remove the trunk's firewall which will be necessary to add fluid, on using the proper fluid etc..
Additionally; if you need to add fluid, at that time, I would strongly recommend replacement of the pump's motor staring relay, because as it it switches very high electrical current, the contacts arc, which can cause contact pitting (e.g. motor will no longer operate) or fuses the contacts permanently closed (e.g. motor runs continuously and burns out).
The Mercedes OE relay is part # 0025427219 and is an inexpensive wear replacement part. The genuine MB part is available from FCPEuro, who is also a forum sponsor, for less than $13 at https://www.fcpeuro.com/products/mer...lay-0025427219 and they also offer the OEM Hella replacement part (e.g. without the MB logo) for only $6 at https://www.fcpeuro.com/products/saa...0-9000-8522310 . Note: I keep a spare on hand, because this is the same multi-purpose relay, that is used in many other systems throughout the car (e.g. fuel pump, starting motor etc.),
Old Nov 18, 2018 | 03:34 PM
bit lost's Avatar
thank you
wow i certainly wast expecting all that info. thank you so much it has helped me immensely...
Old Nov 20, 2018 | 04:38 PM
jinark's Avatar
Veteran: Navy
2003 CLK 320 convertible
Mine was low a few years ago and I followed the procedure in the above links Serndipity provided to get to the reservoir, add fluid and bleed the system. Although it at first seems daunting, it's really pretty easy, just take it step by step. The closest Mercedes dealer is 80 miles from here so I found the fluid on Amazon. ZH-M hydraulic fluid, I probably overpaid by using the genuine Mercedes branded fluid, but I know it's compatible with what was in the system.
