Doube din in 1999CLK320?
Old Nov 22, 2018 | 11:16 PM
Saadali's Avatar
1999 CLK320
Hi guys,
Very new to this forum, but I did have a good bit of looking around and I could seem to find any information on installing a doubledin stereo into a 1999 CLK320. Even with removing the stock radio+the little storage unit, you have a little black plastic separator. Is there a way to remove this to throw a nice touchscreen stereo in there? I haven't been able to see a way of removing it.
Thanks all!
Old Nov 27, 2018 | 11:06 AM
Joseph Donovan's Avatar
2001 Mercedes Benz Clk320 Coupe
Originally Posted by Saadali
Hi guys,
Thanks all!
I have the 2001 Clk320 coupe with an aftermarket kenwood ddx773bh hooked up in it. Same production line if I am not mistaken. Because of the complexity and irritation wiring this up myself I recommend save yourself some time(not money) and opt in to have it professionally installed. If you must go diy due to finances, the wiring harness is actually a metra wiring harness for a vw. Hope that helps.
Old Nov 27, 2018 | 07:34 PM
Saadali's Avatar
1999 CLK320
Awesome, thanks a ton for the info mate. I would prefer to do it DIY so I will likely go with a wiring harness. I take it you had to cut out the plastic separator?
Also, did your stereo fit perfectly or did you need to buy a facekit thing?
Old Nov 30, 2018 | 05:48 PM
Not exactly. The only thing I had to hardwire was the 12v+ for the switched, the amp power and the 12v constant and instead of using a jumper off of the ignition fir the switched i tapped in to my cigarette lighter for switched power because its much more convenient. Its a pink and green wire if i remember correctly. As per the dash kit i purchased one at Bestbuy when I bought the head unit.
Old Dec 2, 2018 | 11:19 PM
MarcusF's Avatar
2002 CLK430
This may help - thesouthweststar.com/MBF/headunit2.html
I did mine ages ago.
Old Dec 31, 2018 | 06:56 PM
kfwa's Avatar
MLK 430
Hello everyone, new to the forum
I just bought a 2000 CLK and have been searching various sites trying to find information about buying a double din kit to support the installation of a double din aftermarket stereo.
So far I've only been able to find a higher end kit for around $200 that is designed to support the installation of a double din in my car.
Much appreciated if someone could point me to a metra or otherwise affordable double din installation kit that works.
Old Jan 4, 2019 | 01:49 PM
MarcusF's Avatar
2002 CLK430
I'm in the midst of another upgrade. I installed an Alpine iLX-207 in a W208 this week. The iLX-207 is a double DIN and no "kit" is needed. It simply fits the hole left by the single DIN and the sleeve. Although I hate cutting anything, I did have to trim the divider to make room for the monitor. The iLX-207 is a fixed double DIN touch screen attached to a single DIN base unit.
Like the old Alpine I replaced, all the original Mercedes features work - the steering wheel controls work and the PAC audio Bose converter is in place. This new unit adds Android Auto and a rear view camera.
