Shiftier connector help needed
Old Dec 16, 2018 | 03:06 PM
karayjay's Avatar
2006 CLK 350/. 2009 CLK 350/2005 Both White
I need to disconnect a wire connect that goes from my shiftier module to my shiftier base and it wont come out. I don't want to damage it it seems like there is a clip holding it back that need to be released... I need to get it for for the replacement shiftier I am buying ....Here are the pictures of the connector
Old Dec 16, 2018 | 04:34 PM
karayjay's Avatar
I just realized that when I get the new or used shiftier that will not be an issue what I have done is separated the 2 sections ....If I removed the unit as one this would be be an Issue
Old Dec 21, 2018 | 12:50 PM
karayjay's Avatar
ALL SET FIXED bad shiftier so when you are in limp mode and your shift display is bank get a shifter mine was 60.00
