W208 Convertible Rear Window Stuck Up
Old Apr 23, 2019 | 02:45 AM
steveoelliott's Avatar
W208 CLK Cabrio 230K
Hi all,
Yesterday I encountered an issue with the right hand / driver's side rear window sticking in the up position when lowering the hood. Even manual operation using the rear window switch fails to move the rear window.
I checked the related fuses and all are OK. Also when I try to operate the offending window I do hear a click from the rear so it clearly has power.
I suspect this is likely to be a window regulator or motor issue. However, am I correct in assuming if it were the regulator then the window would have fallen into the door? I had this happen on a Seat once.
Thanks...
Old Apr 23, 2019 | 05:46 AM
Wow... What is even more peculiar is this morning, I've just gone out to the car and the window now works.
Old Apr 29, 2019 | 01:03 PM
Mercnotworking's Avatar
CLK 230 Convertible 1999
Good for you.
Doing anything with the 208 cabriolet rear window is extremely fiddly.
I recently replaced my rear window and it took me about 30 hours total because there is no documentation and I don't know nothing about diddly squat.
I wrote this article to help: https://mbworld.org/forums/clk-class...ar-window.html
Love and kisses
David
