Convertible Control Module
Old Sep 26, 2019 | 12:19 PM
Monohuebs's Avatar
2001 CLK 430 convertible
So, mechanic says my convertible control module needs replacing. (yes I believe him and have gone through everything, so that is the issue).
My Question is: if I get a module out of my exact same car (2002, CLK 430 convertible), do I have to have the unit reprogrammed or is it simply a plug and play?
Old Sep 28, 2019 | 05:35 PM
Mercnotworking's Avatar
CLK 230 Convertible 1999
CONVERTIBLE ROOF ECU A2088201126.
If this is the beastie that you're talking about then it should be plug and play. When I replaced it on my convertible, the power roof worked in exactly the same way as it did before the replacement.
Old Oct 13, 2019 | 08:24 PM
CapitalB666's Avatar
2002 CLK 430 Convertible
Hi
I have just changed the ECU on mine the important bit is the part number MUST match Mine was the A2088203026.
Serndipty is the genius on roofs on here he was a great help to me on some models there are 5 solenoids on the pump and some have 7, so there are different modules.
If you go to benzcat.com and put in your vin it will tell u what equipment etc should be on the car.
I hope this helps.
Rob
Old Oct 25, 2023 | 04:43 PM
cjhazard's Avatar
SL500, G500, Tesla Roadster, Tesla Model 3 Performance, Willys CJ2A, Toyota Tacoma
I'm trying to locate my convertible top control module, does anyone know where it's located?
Old Apr 2, 2026 | 03:31 PM
Brutis Khan's Avatar
Does the module need to be programmed in 2003 sl500 if replaced with different one or no?
Old Apr 3, 2026 | 06:30 PM
Mnay apologies, I don't know the answer but I think it would be very difficult, if not impossible to swap clk roof cpu with an SL500
