On and off check engine light...
Old Aug 2, 2004 | 12:55 AM
jawong's Avatar
w201
Angry On and off check engine light...
is pissing me off!!!!!!!!!!
I brought it in to get it checked and found it was one of the O2 sensors.
But why does the light keep coming on and off....??????? I want to bring it in again to get it checked to make sure that it's only one of the four sensors before I order a replacement...can a diagnostic be performed when the check engine light is off??? This friggin light comes on at the most inappropriate times (weekends and evenings when my garage is closed).
Old Aug 2, 2004 | 01:51 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Yes, the diagnostic will tell you which O2 sensor(s) is(are) bad, even with the CEL off.
-s-
Old Aug 2, 2004 | 01:20 PM
jawong's Avatar
w201
thanksssssssss!
Old Aug 2, 2004 | 04:16 PM
CHB's Avatar
CHB
'79 300D, '85 300Dt, '99 CLK430
Exact same thing happened to me, and they told me it was one of the 4 O2 sensors. I just put 94 octane gas in once in a while and the light does not come on anymore
Old Aug 5, 2004 | 05:20 PM
fast_car's Avatar
1999 E320 / 1988 BMW 635Csi / 1987 Porsche 911 TL Cab Triple Black
Post
So I can take my car to the Benz shop and have them check and see which O2 is bad, then buy the part and replace them myself.
How hard to replace it ?, would you notice the performance of the car if O2 is bad.
TIA
What Benz shop in San Jose (bay area) would you recomend to take the car in for diag when CEL on/off intemittenbtly.
and how much does it cost for diag test
Tan
Old Aug 7, 2004 | 05:06 PM
clkal's Avatar
01' CLK55
TIA
Tan
actually when 2 of my O2 sensors were bad, the check engine light just came on. It didn't go on and off....however, when my mass airflow sensor went bad, the check engine light came on and off intermittently.
Old Aug 8, 2004 | 02:10 AM
jawong's Avatar
w201
well the CEL has come on after three days of driving but like scorchie said, I had the diagnostic done when the CEL was off...bad O2 sensor...luckily just one. Gonna get it changed ASAP.
Wouldn't the rich fuel mixture eventually burn out the catalytic converter if the sensor's not changed??
