cd changer not recognized
Old Aug 5, 2004 | 07:51 PM
sungulent's Avatar
2002 mercedes clk coupe
if anyone can answer this please do so...1999 clk430 radio is operating but when the cd button is pressed on the head unit the messege comes out as NO CD CHANGER...please respond
Old Aug 5, 2004 | 10:07 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I didn't really see a question in your post, nor if you did anything to remedy the situation... I'll assume you do have a CD changer installed? Can you eject cartridges?
-s-
Old Aug 6, 2004 | 12:16 AM
RED-CLK's Avatar
Have you checked the connections on the Cd changer in the trunk?
Old Aug 6, 2004 | 12:51 PM
joeray's Avatar
2000 CLK 430 Conv.
It has happened to me once every so often. I turn on the car and
see the 'NO CD CHANGE' message comes on when I push the CD button.
It some times goes away when I turne off and then on the car.
Some times the next day the problem goes away.
It doesn't happen that often, so I've never looked into what might be wrong.
I think there was another post a while back on this subject/problem.
Old Sep 13, 2004 | 04:26 AM
Talos's Avatar
W208 CLK320
I have the same problem, and can't eject the cartridges. It's also not "fixing itself" as yours did...
Old Sep 13, 2004 | 11:16 PM
rajah996's Avatar
CLK55, CL500, Q45
try moving around the cables on the cd changer, or taking
the battery off for a while. (the battery thing seems to fix
alot of stuff on MB's for some reason)
Old Oct 1, 2010 | 04:52 PM
monkfunk's Avatar
2001 Mercedes-Benz CLK55 AMG w/BBS 18" Rims
I have the same issue - 2 weeks ago I unplugged the battery and reset everything (windows, sunroof, radio, etc....) and now I am getting the same error again saying no cd changer - what gives, why does this keep happening? I don't want to unplug and reset my whole car again... what is causing this stupid error and how can I fix it for good?
Old Oct 2, 2010 | 01:16 AM
MarcusF's Avatar
2002 CLK430
For this problem, unplugging the CD changer itself is the same as unplugging the battery. To disconnect the changer, just disconnect the power. The fiber cable doesn’t matter, although to remove the changer (which you may want to do) unplug the fiber too, and the couple of screws holding the changer in. Removing the changer won't necessarily allow you to remove the six disk cartridge. I've found when the changer is uncooperative, pushing the eject button, and tapping the changer with my fingernail is enough of a shock to get it to eject the cartridge.
Personally, I've gone this route.
Old May 24, 2011 | 01:29 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
I have the same issue. My friend has a 2002 Clk 320, and when you hit the cd button on the radio it says "no cd changer" etc. So, I can just unplug all the cables to the changer and this may fix it??? Any other tips???
Old May 24, 2011 | 03:08 PM
Jason B's Avatar
Ok, update. I removed the changer, and unplugged both the fiber optic and the power plug for 30 min. Nothing changed after plugging it back in. It will eject, but that's about it. After I slide the magazine in, nothing else happens. I think it used to load the cds after it clicked in place, can't remember. All I know is, the radio says "no cd changer" when you hit the button. So is it the changer that's bad, or the radio that's bad?
Old May 24, 2011 | 05:11 PM
MarcusF's Avatar
2002 CLK430
In most cases, the head unit knows the CD changer exists and is in place. The 'cartridge / magazine' is the problem. The changer doesn’t sense the magazine, and it broadcasts a "cartridge not in the slot" alert. That’s why you see the error message. As you’ve seen, killing the power does zip, because power isn’t the issue. That also explains why tapping the magazine used to occasionally work for me - the tapping triggered whatever the changer uses to sense the magazine. Your friend could use this as an opportunity to upgrade the head unit. After 12 years, it may be just plain worn out.
Old May 25, 2011 | 10:08 PM
Jason B's Avatar
Thanks for the reply! I did some more digging and it seems if you manually mess and try to turn the "worm" gear inside, that can free up the unit and make it sense the cd's after you put the mag in. See here:
http://blogs.oracle.com/miko/entry/cd_changer_repair
Some of the replies suggest the same issue I had, and moving the gears around manually can get it working?
Old Sep 29, 2013 | 11:14 PM
Iamsecond's Avatar
2002 CLK 430
THANKS FOR THIS...IT'S ALIVE! MY DISC CHANGER IS ALIIIIVE!"
Old Oct 17, 2013 | 02:59 PM
matt1's Avatar
2000 clk320
My cd player had the same issues. 10 swift taps with a framing hammer and BOOM! I now have a cd player
Old Oct 18, 2013 | 06:19 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
This exactly what I did when I had the same problem. This is an opportunity to do an upgrade. That said I kept allof the original parts and wiring so that if I decide to sell it all of the OEM gear goes with it.
