ABS BAS ESP lights
Old Aug 27, 2020 | 08:37 AM
Southcoasting's Avatar
2002 clk 430 cabriolet
ABS BAS ESP lights
All three lights are on I changed BLS. As soon as I step on brake pedals all 3 lights come on any ideas??
Old Aug 28, 2020 | 12:00 PM
convicted's Avatar
1998 CLK 320
ABS Sensor?
Old Aug 28, 2020 | 03:23 PM
Originally Posted by convicted
ABS Sensor?
where is that located?
Old Aug 28, 2020 | 06:51 PM
convicted's Avatar
1998 CLK 320
This may help: https://www.google.com/search?q=merc...hrome&ie=UTF-8
Old Sep 2, 2020 | 05:58 PM
cindyclk's Avatar
Did you buy an OEM BLS or ebay/China?
Old Sep 2, 2020 | 09:27 PM
cm60k's Avatar
Many things could cause those lights,
(bad BLS/one of ABS sensors collapse/bad TB/malfunction of ESP module/bad ESP-ABS pump),,
prefer to diagnose the car, codes will narrow the issue.
-;-ZAYED-;-
Old Sep 2, 2020 | 10:09 PM
cindyclk's Avatar
-;-ZAYED-;-
This issue has been talked about for years with the exact symptoms above...defective brake switch ($15 at dealership).
Old Sep 4, 2020 | 01:26 AM
OEM
Old Sep 12, 2020 | 06:46 PM
cindyclk's Avatar
If it is OEM from dealer, I would check that the wires are correct...or get another one ...seems like the only inexpensive part at the dealership
Old Sep 27, 2020 | 05:00 PM
which wires?
Old Sep 28, 2020 | 05:03 PM
cindyclk's Avatar
those attached to the switch
