Windshield washer nozzles are loose.
Pete
Yours either broke off or are to depressed to go back to original position. I had to remove mine to paint the hood. The issue of removing them is if they are really old the 90 degree nipple might break off inside the female end of the sprayer. I had to replace my whole hose because mine nipples broke off and I could not locate just the 90 degree nipple. If the tab is still there, I'd use a heat gun to soften up the plastic tab and bend it back ever so slightly with some sort of a hook. Be careful as you might over heat the are and make the paint bubble up
Pete
Pete
